Since we are discussing servos, I would like to add that the 1/4 scale servos are also very good options if you are scratch building mounts. Even if the ratings are a bit lower these beasts just move the wheels. I have compared 2 hitecs, one std size high torque (forget the p/n) and a similar spec 1/4 scale. No comparision, the 1/4 scale servo moved the wheels when the high torque std would not, and it held center better as well. Just another option, and mainly for large vehicles, as these servos will not fit most places.
Well if you are targeting 'bashers' too, then brushless (sensored/sensorless) support is required. No one bashes with brushed, unless you specifically mean 'crawler bashing'.
But anyways, what about the MMP and the TM? Any correlation between the two other than both coming out of CC...
No correlation between the MMP and the TM, although I wonder if my prodding about having an adjustable BEC on my unit influenced the design of the MMP. Care to comment Patrick?
If I remember right it was a trade off between power and adjustability. I wanted power.
