For the MMM adjustable BEC -- the hardware for adjustable BEC has been in the V5 hardware from the beginning, but we just now added the capability to change the program settings in the Castle Link app.
V4 and earlier hardware doesn't have the ability to change the BEC voltage, and will not show as an option.
Thanx!
Patrick
Interesting I say. I got my MMM two years ago (in an brushless emaxx).
I was pretty sure i had V3 but CL does show this option. When was the V5 released?
You sure it's two years old??
Patrick del Castillo
President, Principle Engineer
I forgot i changed my MMM about 6 months ago
I accidentally did some -20 C "waterproof testing".
Thrust me, jumping onto a frozen lake, braking through the ice and having the water freeze before you bring your car home is no good for your ESC
So if both, V4 and V5 have hardware for BEC voltage changing how can i know which Version i have?
Sorry for messing things up...
Ah, you can't tell between V4 and V5, not from the outside. Sorry!
What about the Transistors? You have mentioned that MMExtreme (traxxas) has better/newer trans and new MMM has the same ones.
Does the V4 have those or its just the V5?
Well, the V5 can have either / or -- either the new transistors or the older ones. Depends on when it was made.
Speaking of which, is there an expected date when the MMPro case will be back in stock? They seem to be on international backorder, and I miss running my SCT Pro system.
Thank you.
