Hustler
Hustler's Avatar
07.05.2006, 06:22 PM
I am in Gainesville squee..how abt u? And thanx for the link newuser. U guys r very helpful.
Hustler
Hustler's Avatar
07.05.2006, 07:36 PM
so with http://www.rc-monster.com/proddetail...HPI_BUGGY_DIFF I wont have to get anything else right..!! I mean the stock shafts would fit right in and the bulks would be good to go as well..!!!! I dont see where the third shaft would go.? Does this diff have a hole on the side for that third shaft?
squeeforever
squeeforever's Avatar
07.05.2006, 10:53 PM
Well I live in Lousiana....but maybe you meant Leroy? He's in Woodford...
No, you need cvds all around with the buggy diffs. MIP and UE are just about the only ones you can use. CVD's and the gear sets are all you need though.
Hustler
Hustler's Avatar
07.06.2006, 01:26 PM
Well, Sorry for the confusion, I meant coolhand as far as the whereabout goes.
Would I also need the center drive shafts as well..?? or the stock ones will do with the hardened diff..??
Thanx for the input guys, I will keep you guys posted occasionally as I progress.
neweuser
neweuser's Avatar
07.06.2006, 01:38 PM
I sent you a pm, you will need centers as well. i found some stuff for you you may want to check out.
A can of worms
Hustler
Hustler's Avatar
A can of worms - 08.18.2006, 11:30 PM
Alright, so I thought this was gonna be easy. Well, I guess, I was wrong. I got the hardened diff gear (Differential: C8084-1, Pinion: C8030). Also got the cvd's (http://cgi.ebay.com/ws/eBayISAPI.dll...ME:L:RTQ:US:1) to go along with my hybrid bulks.
Now, a couple of problems that I ran into. First, I didnt get the bearings with the pinion (center shaft), but I can grab them from my local hobby shop tom morning. Secondly, the cvd's arent long enough to fit in the differential..!!
What did I do wrong, how do I fix?
You guys have always helped.
Thanx
And the hybrid bulks, diff etc are gonna make the truck "very" heavy. I hope I can beat the 3.3 after I am done with this thing. (7 or 8xl with 9920 is the plan for now).
squeeforever
08.18.2006, 11:33 PM
It shouldn't make your truck to heavy. What diffs did you get?
Hustler
Hustler's Avatar
I got it from the local hobby shop.
squeeforever
08.18.2006, 11:52 PM
Those should be fine. They shouldn't give you any length problems.
Hustler
Hustler's Avatar
08.19.2006, 12:00 AM
Well, the cvd isnt long enough to go into the cup thats attached with the differential. I am not missing any part right?
Also, what else would I need beside the bearings for the center shaft. The center shaft doesnt seem to connect to center cvd very well either coz its a lil bigger then the stock one.:019:
I can post pics if that would help.
squeeforever
08.19.2006, 12:03 AM
Yes. Post a picture. The center will require a different drive cup since it's a bigger output shaft. Get the LSP one intended for them and it should be right.
Hustler
Hustler's Avatar
08.19.2006, 12:24 AM
U got any link to those bearings by any chance?
Thanx for the quick responses.
Hustler
Hustler's Avatar
08.19.2006, 12:26 AM
squeeforever
08.19.2006, 12:28 AM
Looks like you might have gotten ripped on those CVD's. I don't think there 2.5 CVD's....
Hustler
Hustler's Avatar
08.19.2006, 12:47 AM
whats the size of the widemaxx cvd's?
