08.08.2006, 11:26 AM
Um, that motor doesn't look too healthy to me...
jhautz
jhautz's Avatar
08.08.2006, 12:12 PM
Originally Posted by stampy
i think your right they are 4mm lame:002: what about a lenher xl 3600 would one work in a rusty? a new motor is a must now! :035: dont know what happend but i know its bad
The XL3100 would be great in a rusty. I ran a XL4200 for a while and it was really good. But I went to 3s Lipo and needed to get a lower KV motor.
You could even just run the Basic 3100 (not XL) and it would be really good.
to make it...
or break it...
Silent...But Deadly
stampy
stampy's Avatar
08.08.2006, 12:39 PM
nvm its 97 amps:031: any body know how powerfull a Kontronik Twist 42 is? jamie from starluck said he would sell me one for like 140 should i do it:002:
jhautz
jhautz's Avatar
08.08.2006, 01:16 PM
4200kv seems like it would be too much for 11.1. You will be reving it really high and it will probbly run hot. I got rid of my XL4200 cuz it ran to hot on 3s. I would recomend going for something more in the 3000-3500kv range. You can gear ir up and get just as much speed, it just runss cooler. Especially if you go w/ the basic XL. It will have plenty of torque to gear it up.
I really think the Basic 3100 would be ideal for a rusty on 3s.
to make it...
or break it...
Silent...But Deadly
stampy
stampy's Avatar
08.08.2006, 12:20 PM
would a xl3600 on 3s work well with my quark 80b?
squeeforever
squeeforever's Avatar
The XL3600 should work well I would think. Somebody correct me if I'm wrong though.
jhautz
jhautz's Avatar
08.08.2006, 01:27 PM
I think the XL3600 would be fine as well. I wouldn't go any higher kv than that though or it will run to hot. As far as the 97 amp rating. You won't draw anywhere near that on 3s with a light rusty. If you had it geared up on 4s in an emaxx or something then you might.
When I had my XL 4200 in my (relatively heavy) all aluminum rusty, it would peak at 68-70 amps on 3s and that is a more power hungry motor than the xl3600. Your quark is an 80A constant rating. I ran my XL4200 on a Warrior 7020 (70 amp rating) w/ no issues. You will be fine.
to make it...
or break it...
Silent...But Deadly
stampy
stampy's Avatar
08.08.2006, 01:21 PM
97 amps is to much for the 80b though :(
squeeforever
08.08.2006, 01:24 PM
You can't go by that rating...The XL3600 in a ST on 3S shouldn't pull that many amps.
stampy
stampy's Avatar
08.09.2006, 10:16 AM
cool sweet guees ill order it up today :018:
