cemetery gates
12.03.2006, 11:42 PM
Originally Posted by BrianG
Cemetary: I remember that truck now. You had a close-up of the motor mount in another post somewhere a while back. Do you still have that picture (or a link to the thread I'm talking about)?
Umm... uhh...
page 1 of this thread?
Bye:018:
12.04.2006, 12:09 AM
:p OK, so I'm blind! This is the one I'm talking about:
I know you've added those angled bar supports in a previous pic since the one above was taken, but it seems that the motor mount itself is kinda precarious - like there isn't enough stuff holding it in place.
cemetery gates
12.04.2006, 12:18 AM
well, i have the back of the motor supported
neweuser
neweuser's Avatar
12.04.2006, 12:37 AM
Still think it could use some support though, but nice job!
12.04.2006, 01:11 AM
Actually, I think the motor might be moving back and forth (front-to-back). It seems like there is enough up/down support. You gotta remember the forces the motor mount is subjected to. What might seem a solid mount by a test "wiggle" may move all over the place when the motor is running and the truck is bouncing all over the place...
JOHNNYMAXXIMA
RC-Monster Dual Brushless!
JOHNNYMAXXIMA's Avatar
12.04.2006, 06:01 AM
Hey, I have that same dryer! Oh yah, nice truck too.
Procharged5.0
Procharged5.0's Avatar
12.04.2006, 12:15 PM
Nice work man!
Serum
Serum's Avatar
12.04.2006, 01:24 PM
Brian;
Looks like he is using a horizontal brace on the front plate (actual motorplate)
But that's not supporting the entire motor. Try to hook up a brace that actually connects the motor to the front or rear bulk.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
12.04.2006, 01:44 PM
I agree, the motor plate should be thick above 2mm thick, and extend down to the chassis, if there is material below it? I can't tell. You would be better making a bigger motor mount, instead of front and read 'lighter' supports. It seems like it might just snap it if have a really good landing/crash/roll over.
Nevertheless, the motor mount does look kinda kickass in a way.
coolhandcountry
coolhandcountry's Avatar
12.04.2006, 07:12 PM
If the chassis flexes any it will pull the mount off a little. A little with alot of
pressure is not good. Just an idea.
Peace!
Country
Help support the
Rc-Monster
Buy here
cemetery gates
12.04.2006, 08:50 PM
well, I think I might have an idea to fix the chassis flex.
In the picture below, the red lines represent aluminum angle. If I connect the front and back bulks I think that will get rid of any chassis flex back and forth; Which is the problem. :eek:
After I'm done with my homework, I'll put on those chassis braces...
Bye:018:
