glassdoctor
TEAM FUSION
glassdoctor's Avatar
01.14.2007, 11:19 AM
I would think 4 shoes would help the clutch grab better... but also, you can add weight to the shoes. That's one of the tuning options for nitros, either drilling out some material to lighten them or adding something to make them heavier. I've never done it myself so I could only guess how it's supossed to be done. A nitro guy could tell you...
Does the car nosedive if you hold the throttle steady over the jump? If you are hitting a jump full throttle then try to only back off to like half throttle in the air... never let off all the way... and you should be fine. It should fly pretty level without extreme throttle inputs.
As for the brakes, you might want to check out the "building losi eight" thread at rctech.com forums... there is a lot of talk about the brake servos dying in the 8ight. You also mentioned using a smaller servo fo rthe brakes..... don't do that. You want a good strong servo there.
squeeforever
squeeforever's Avatar
01.14.2007, 02:21 PM
You're right. You can add or remove weight from the shoes to change how they grab. There is actually a company making some that have like 3 or 4 set screws in them that you can remove to change that. He might want to look into that.
GorillaMaxx360
GorillaMaxx360's Avatar
01.14.2007, 04:50 PM
Very nice i love the eight series but especially the truggy one.
starscream
RC-Monster TQ
starscream's Avatar
01.14.2007, 06:31 PM
Thanks for the advice on the clutch shoe weights
I've got plenty of set screws on hand so I'll mod a couple shoes with them and see how it goes.
Thanks!
Ha Ha
The Flashlight Strikes Again...
starscream
RC-Monster TQ
starscream's Avatar
01.15.2007, 07:39 AM
I am also looking into a one-way solution for my motor.
All of the one-ways I've seen use 6mm shafts.
Does anyone know of a one-way that uses a 5mm shaft?
Ha Ha
jhautz
jhautz's Avatar
01.15.2007, 08:20 AM
The one on the center 2 speed for the XTM Mamoth or XLB uses an 8mm shaft. Not 5 but different from 6mm.
to make it...
or break it...
Silent...But Deadly
gramey
gramey's Avatar
08.27.2008, 12:11 PM
Nearly done, just waiting for my MGM esc which my LHS cocked up the order on and I'm there, hooorah!
TeknoRC 8ET conversion, Neu 1515-1Y motor, Track Power 5000mah 4S lipo and soon to be MGM 16025 esc.
Losi 8T RR - Novarossi Plus 21-5BT/ Jammin JP3 - Teknorc 8T - Neu 1515-1Y - MGM 16025-3 Z Series ESC.
