overkill5000
gmaxx addict
overkill5000's Avatar
05.02.2007, 03:51 PM
Originally Posted by ssspconcepts
Well, I received some more parts for my latest build. I have the FXT arms and a FLM suspension arm brace. I should receive the rest of the suspension parts and drive shafts today....UE shocks and driveshafts.:028:
I appreciate all the good help you guys have provided.
i see you have the cam locking bell cranks where can i get some!!!?:032:
GorillaMaxx360
GorillaMaxx360's Avatar
05.02.2007, 06:04 PM
how does the servo saver/steering bellcrank work with the chassis. my proline one binds and i want a better one but the ue one is always out of stock. do you know about when they will be back in stock or somewhere else i can get them.
ssspconcepts
ssspconcepts's Avatar
05.02.2007, 10:31 PM
The UE is better...than the proline...but I have the proline on my other truck is does fine.
I got tired of watching the web for the UE saver. I ordered one and followed up with a couple of emails to Robin at UE and he got me one! Apparently the small sealed bearings are what holds up the process...he has a hard time getting them in stock.
overkill5000
gmaxx addict
04.25.2007, 09:13 PM
i just recieved my UE cv's they work great w/flex tek susp. arms w/1/8 scale truggy gears on my emaxx gmaxx............i ran my truck for the first time today and im back to breaking things....the first part was the proline steering bellcranks and then the rear wheel drive i think the tork chewed up my 1/8 scale truggy gear .......but thank you all for the advice the UE cv's fit perfect!!!!!!!!!!!!!!!!
neweuser
neweuser's Avatar
04.26.2007, 08:57 AM
What diffs are you using?
Serum
Serum's Avatar
04.26.2007, 02:04 AM
Good to hear you can wreck it again.. :p
overkill5000
gmaxx addict
04.26.2007, 12:24 PM
i took my truck apart to see what broke it wasn't my diff gears after all i just lost the little hex screw that holds my diff cup on!!!..im using hot bodies 1/8 truggy diffs in a hybrid bulk head they work well!!
neweuser
neweuser's Avatar
04.26.2007, 12:27 PM
I see, hotbodies are good diffs. When you replace the "hex" screw, or grub screw, use loc tite. People like to use blue, but I use red....
GorillaMaxx360
04.26.2007, 12:57 PM
what grub screw are you talking about. the one that allows fr the pin to come out is this the one.
Serum
Serum's Avatar
05.02.2007, 02:45 PM
Cool..!
What knuckles are you going to use?
ssspconcepts
05.02.2007, 02:48 PM
Originally Posted by Serum
Cool..!
I went with the RPM knuckles with oversized bearings...I noticed that you have them on one of your rides. How do you like them? Alternatives?
I bought the white ones and will dye them green or red.
chopndroptx
05.02.2007, 02:46 PM
Nice brace! Looks better than mine! I didnt even know they made one for the Maxx's.
ssspconcepts
05.02.2007, 02:49 PM
You can get them from FLM directly. $7 gets you two of them delivered.
Serum
Serum's Avatar
05.02.2007, 02:56 PM
You do need longer hingepins with them i pressume?
The timaxx i am building hasn't seen any track/road.. i was waitin for some parts, and now it's on the 3rd place of projects to finish.. Too bad..
The RPM knuckles are okay though, installing the retainer takes some patience. they are tight.
There are no alternatives IMO. i tried buggy knuckles, but no succes. Integy knuckles are not considered an alternative. UE doesn't make the right knuckles anymore.. The only possible neat option i can think of is using Revo 3.3 shafts with rd-racing knuckles . (not too expensive either, 99 for 4 of them)
ssspconcepts
05.02.2007, 10:26 PM
Actually I used the hinge pins that came with the FLM hybrid bulks. Longer pins would have gotten in the way of the servo saver. However, I did have to grind/shave off the collar to the plastic FXT A-arm bushing...I just needed like .05mm to make the hinge pin fit and that did the trick.
I used integy knuckles on my 1st monster truck...that was the straw that broke the camel's back...I'll never buy their products again. I know golden horizon makes some, but I wanted oversized bearings.
