crazyjr
crazyjr's Avatar
08.25.2007, 09:35 PM
It was dealt with on the unplugging, the draging the charger off the table may or may not have been an accident, I never knew. But there were guys cheering because i couldn't charge, oh well. Like i said you might not get that kind of interference, thats what i went through
Finnster
KillaHurtz
Finnster's Avatar
08.26.2007, 02:07 AM
OTOH, there are a few guys charging A123s by directly hooking them upto 12V marine batteries (with some small resistance from a long length of cord.) The "nuclear" charging method as its known.
Linky
Obviously only works in multiples of 12V, but gets her done in 4min. :) No way/time for someone to frag w/ your charging. >_<
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
08.26.2007, 02:14 AM
HOLY $#@! !!!!!!!!!!!
Once I think about it, the voltage of a 12v battery is right around the peak charge voltage for A123's.... that is awesome!
That can't be good for them charging like that though... I know A123 systems uses a 'pulse' charge to charge them in 5 mins, which will reduce heat. Not that they will get hot.
EDIT: Wait, that's a 3s pack? I would have thought they would use a 4s pack... the voltage doesn't make any sense, a 12v battery is higher than 12v... it would be 14.5 volts at those amps.
supralover72
supralover72's Avatar
08.26.2007, 02:30 AM
^You can only charge up to 3s A123's at a time I believe with a balancer.
Finnster
KillaHurtz
Finnster's Avatar
08.26.2007, 02:31 AM
Some great A123 testing and other links. Plane guys are way ahead on these things (as they were w/ lipos)
link 1
Link2
L3
L4
Huge threads, but lots of good buried info. Hooking upto power supplies, generators, marine batts, all sorts of stuff, including more normal methods. I see MetalMan turn up now and then. :)
