Compliantguy
07.12.2005, 03:09 PM
That's correct. I drilled 3 holes in the chassis to attach the motor mount.
Although, you will need to find a location to mount the speed control. For that, I made a shelf from 1/8" black ABS plastic and used spacers to mount it above the rear shocks. I used the orginal shock mounting holes with longer screws and I used the original mounting hole where the tuned pipe bracket was located.
