Matthew_Armeni
Matthew_Armeni's Avatar
11.27.2007, 01:32 PM
oh and i also need something that isnt more than 74mm long, as per the conversion by tekno
Well, the Feigao XL motors are exactly 74mm long, but once you add the heatsink/clamp Mike has (almost required to keep the front bell from popping off), the total length goes to around 78mm. I would actually measure to see exactly how much room you have.
The Neu motors are shorter, but larger in diameter. Don't know if there are any diameter limits...
The Feigao motors fit with Mikes clamp, that's what I'm running now. The Neu motors fit as well.
  Send a message via AIM to Matthew_Armeni
