So the actual diff cup is the same size as the 1/8 scale diffs?
No they are not the exact same size . All the big beval gears are shaved down . They are the same size in diameter as in a 1/8 but are thinner ( shaved down ) . So they have a shallower cup, but not by much.
You did a great job with you battery tray...you should sell those. I ended up using the Tekno RC Revo battery tray on my CRT.5 EXT Chassis. I got lucky because the bolt pattern matched up perfectly.
Thank's Your ext.5 looks great . im still using the stock chassis.
