drkros3
12.10.2007, 12:22 AM
well i might upgrade to the neu motors then. since it would run cooler and longer and im going to start racing my revo.
12.10.2007, 01:47 AM
Not sure if you care, but the hacker motors work well with the mm esc. I run a few different hacker c50 and b50 cans and they are very good motors. They stay cool and are much more effecient than the feigao, which are supposed to be hacker clones(not). The prices are high, but if you check hacker's website the have a sale section that usually has motors under $200 which is good deal IMO.
drkros3
12.10.2007, 01:51 AM
wow i totally forgot about hacker motors. i might have to check them out. thanks
mkrusedc
NeuMaxx
mkrusedc's Avatar
12.10.2007, 10:16 AM
You putting this in a Revo? I think part of my cogging issue was that I could not gear small enough because the motor hit the E-Maxx Tranny. Maybe someone else an answer this. Can you gear smaller on a Revo tranny then an E-maxx tranny?
drkros3
12.10.2007, 11:02 AM
yah its going into a revo with the stock tranny.
and yah i think you can gear lower then a emaxx tranny i think.
12.10.2007, 11:14 AM
Dunno about that, the largest sput you can get for a revo is a 40t (stock). You may be able to fit a larger modded spur but I am not sure. The revo tranny ratio is different, that is why the spurs are smaller than the emaxx. Both the revo and emaxx have the same diff ratios. An emaxx can have a pretty high ratio, especially with 32p gears. Like 10/72 would be 7.2/1 ration, where a revo may fit 10/40 : 4/1 ratio. Use briang's calc to figure out the various ratios for the tranny.
Finnster
KillaHurtz
Finnster's Avatar
12.10.2007, 04:01 PM
The Revo tranny is much more flexible as far as gearing goes. There are not really any clearance issues as the motor does not lay next to the tranny. Also, don't forget that the 2nd gear ratio is changable. Put in the narrow ratio and you can get a very high FDR (over 20:1) Top spd will suck tho.
I thought MGT spurs fit as well, but they are not really needed regardless.
Fine Design sells a large line of LMTs now, including the 1940s and 1950s. The 1950s are ~$50 more than a Neu 1515, but it would work w/ the MM. They are excellent motors tho. He's kinda of an ass, but he's the only game in the US for LMT motors. I've ordered a couple things ferom him in the past w/o issue, but some have had problems.
