Good news
BashOn
Good news - 02.05.2008, 08:48 PM
Well whoever said the Neu 1521 (old design) has a screw on front bell was correct. I was about to apply some loctite and started twisting. To my pleasant surprise threads started showing. I backed the can out a little, applied some thread lock and tightened it up good. I used blue thread lock. If that doesn't work I'll move to red.
I feel much better knowing that the can screws down.
jhautz
jhautz's Avatar
02.05.2008, 09:52 PM
I used a thick CA in one of my Feigaos and it worked good. I thought it would be too strong, but I just added a small amout in 4 places. In case you need to replace bearings, all you do is heat it to soften up the CA.
Yea... and we all know how easy it is to heat up a feigao. Just run it for 5 minutes.
to make it...
or break it...
Silent...But Deadly
lutach
lutach's Avatar
02.05.2008, 10:15 PM
That was a good one. I meant I used my little torch on the places I used the glue. Heat generated by the motor didn't make it come loose.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
02.06.2008, 02:21 AM
I would not use red lock tight on that, for 'whatever' reason you might have to take it apart in the future, red will be 'near' impossible to get off.
