Originally Posted by drkdgglr
Do you think 80mm is too much for the muggy?
Because I didn't want to wait for the larger motors, I got a 60mm 1300kv medusa for my muggy. Only had one run on 8s so far, but it did really well. I'm thinking the 70mm 1200kv might be just right for the muggy on 8s.
I like how it runs on 4s. It's very powerful and even with the soft start cranked up on my MGM it'll launch like a scalded dog. The 70mm would be fine, but I like that extra bit of power
I've still got the massive stock tires on mine (and I actually like them a lot) so that needs more power to move around. If you are going to an MT (Revo, Savvy, etc.) sized tire the 70 should be fine.
I E-Mailed Mike about getting heatsink clamps made for these new motors and he said they will be coming out (didn't even give a hint at when though) but he said that with the motor plate on the front the 74mm XL one will fit the 70mm motor.
Originally Posted by FG101C
Well I'll say this. Comparing a tekno NEU 1515/1/Y/F (2200kv) to the Medusa 36-60-2000kv. The Medusa's must not be very efficient motors. I had the NEU in an SC8, geared 13/46 on 5s and the NEU never got hot, 110 at best. I have the Medusa in my D8 buggy, geared 13/48 on 5s and it gets real hot real quick. The SC8 has diff gearing of 43/10, the D8 also uses 43/10. The D8 and the SC8 also had the same size tires, same set of tires for that matter.
So I went ahead and ordered a NEU 1512/2.5/D/F for the buggy and the Medusa will go in my basher/Corr truck project.
The Neu is 15mm longer and 4mm wider, that's where it gets it's torque. Compare a 70mm MedUsa to the Neu and it'll be closer.
