NeuMaxx
08.24.2007, 10:43 PM
Originally Posted by suicideneil
I believe someone posted on the traxxas forum that the esc was in beta testing, and they were going with a new motor supplier since the old one couldnt meet the standard required, or some't like that. Basically the same thing as they keep saying.
Joe Ford said this several months ago. :(
08.24.2007, 10:52 PM
Judging by the talk saying it's basically a MM with higher current, I'm not anxious anymore. I'd rather have a ~6s setup and use lower current.
NeuMaxx
08.24.2007, 10:56 PM
I already gave up. If my MM cogs too much with my Neu I'll be in the market for a Quark or MGM.
That's All Folks!
08.25.2007, 12:39 AM
I gave up too. Got a MGM 16024; up to 8s!
08.25.2007, 12:43 AM
How has the MGM been working for you bdebde? Any things you would change about it or any problems with it? How are the temps with it while driving?
NeuMaxx
08.25.2007, 01:08 AM
Problems with reverse or braking?
That's All Folks!
08.25.2007, 02:18 AM
Haven't had a chance to try it yet, maybe this weekend.
RC-Monster Captain
08.25.2007, 07:29 AM
My MGM 12032 seems good, but not really smooth.
Nice to meet you!
08.25.2007, 07:58 AM
With what motor Alawi?
RC-Monster Captain
08.25.2007, 08:11 AM
With the 1950/10.
The power is really high, but the motor vibrates like crazy when it's revolving up to it's highest rpm. I'm using 6s with 20T/36T gearing in a slipperential, and I noticed that the motor becomes a bit hot after a few minutes of running while the controller is quite cool. The batts seem warm a bit, too. Any explanations?:(
Nice to meet you!
08.25.2007, 10:43 AM
Possibly under geared, but I don't understand how with a 20t pinion...
RC-Monster Captain
08.25.2007, 11:12 AM
Neither do I, Josh...neither do I...
Nice to meet you!
08.25.2007, 11:19 AM
Well, 6S, with that setup; it's geared for ~60 km/h, you can gear it for 75km/h..
08.25.2007, 11:20 AM
Differential Ratio: 3.3076923076923075
Transmission Ratio: 2.2
Other Ratio: 1
Spur Tooth Count: 36
Pinion Tooth Count: 20
Total Voltage: 20.4
Motor KV: 1333
Tire Diameter (inches): 6
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.017
Spur/Pinion Ratio: 1.8 : 1
Total Ratio: 13.09846 : 1
Tire Circumference (inches): 18.85 inches (478.78mm)
Total Motor Speed: 27193.2 RPM
Vehicle Speed: 37.06 MPH (59.53km/h)
Effective Speed Rate: 1.82mph/V (2.92kmh/V)
Effective KV Value: 1333
Final Torque: Amperage not specified...
08.25.2007, 01:24 PM
Patrick del Castillo sounded so sure when he said something about releasing the MMM in here: http://www.rcgroups.com/forums/showt...=683583&page=5 and still nothing. I've seen people give up on CC MMM and go with MGM and Quark. The MMM should've been out before Summer. Wait a few days and I might post something in here as well as in the Tekin's R1 MT thread.
