Thread Tools Rating: Thread Rating: 16 votes, 4.75 average. Display Modes
Topsy Kretts
Topsy Kretts's Avatar
06.26.2010, 07:27 PM
Your right! way to wide for even my widest body,the JC Manta 0 offset is definitly the way to fly I just set the stock body on the truck with those wheels and tires,never really checked SC bodies for widthWith these wheels on the truck,it's as wide as it is long
timaneli
06.27.2010, 11:22 AM
i am thinking to convert a losi ten of these and run it with vxl combo on 2s only.
will run good on 2s lipo?
you are what you race!!
gone banana
06.28.2010, 09:11 AM
hi guy i got pictures of my ten-t E on rctech i have pro trac rims got an rpm bumper for sc10 20.00 test drove it sunday with a little tuning it while be the fastes 4wd out there
i will put list of thing i did tonight
Topsy Kretts
06.29.2010, 11:21 AM
Thanks Yeah I'll check it out, I waited a while before I bought Mike's conversion to see if the 4x4 class would keep up with the 2wd class. Well it seem to be catching up with 2wd I Love this conversion I used a 1509 1.5y/f Neu motor geared at 54/17 with a MMP esc with 0 punch control to start, HOLY CR&P Batman this thing is the bomb The nitro set-up has nothing on this!!!!!! Temps were just warm to the touch,not worth putting a gun to, that is using 4200mah 4s packs. Diffs are 5/7/3 but may go to 5 in the center to get a bit more steering,really have not played with the shocks yet.This puppy has a ton of potential,and its built as heavy duty as any 1/8 scale out there If you are on the fence about this conversion kit,time to climb off Best money I have spent on RC in a while!!! Thanks Mike and all you Guy's that help point us in the right Direction.
Topsy Kretts
06.29.2010, 11:29 AM
Man, because of the weight of the truck I think you would be tax that set-up too much and burn up your esc pretty Quick
gone banana
06.30.2010, 07:43 AM
sorry for the delay
ID:	9088   Click image for larger version
XXXDAD
XXXDAD's Avatar
Lightbulb 06.30.2010, 09:55 AM
sorry for the delay
So are those the Proline rims they look great... what wheel lugs did you use?
Did the front bumper bolt on or require mods? What bumper for the back? Details Please great job!
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
gone banana
06.30.2010, 03:07 PM
i use proline pro trac rim the bumper are rpm sc10 it come with the rear i redrilled the for the front and used the chassis heated it up to bend a 90 in it
line up with line diff case and drilled and tap 2 4 40 flat head to help support the got small alum. tube tap both end to help from flex
ID:	9091   Click image for larger version
ID:	9092   Click image for larger version
gone banana
06.30.2010, 03:10 PM
more
gone banana
06.30.2010, 03:11 PM
short corse oval truck all alum and fast
Slash 4x4 RPM Bumper on my TEN
XXXDAD
XXXDAD's Avatar
Lightbulb Slash 4x4 RPM Bumper on my TEN - 07.01.2010, 09:46 AM
I used the Slash 4x4 bumper because the two front screws matched perfect,I removed the stock bumper and added longer screws. Still might drill and tap two more screws to make it bulletproof.....
Next is the Proline Protrack wheels they are neg.10* and put you at the legal with.
Teckno has the wheel hexes 12 mm no mod needed:
http://www.impaktrc.com/product_info...cb7f0744b5ad5c
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
FG101C
07.01.2010, 12:04 PM
I got the tekno hexes, yes they are drilled for 6mm axles. The Problem I found is the pins, they use the stock traxxas pins which are much smaller than the pin holes in the axles so there is alot of play. Going to try to dremel the hexes to use the tent pins.
By the way I HATE this POS iPhone, took 8 minutes to type this. POS does what it wants not what I want it to do, pretentious proprietary aholes.
XXXDAD
XXXDAD's Avatar
07.01.2010, 01:24 PM
Oh! How about heating up the pin and melting it into place... use a pair of lock pliers needle nose. heat the pin and brand that baby into the slot... ??? I didnt know!
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
FG101C
07.03.2010, 01:43 AM
I tried filing a stock ten-t hex, that didn't work to good.
Ten Part 2 Rear
XXXDAD
XXXDAD's Avatar
Lightbulb Ten Part 2 Rear - 07.06.2010, 03:46 PM
Here is the Slash RPM 4x4 Rear bumper and the Aarms flipfloped!
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
