Thread Tools Rating: Thread Rating: 57 votes, 4.93 average. Display Modes
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
02.18.2010, 06:01 AM
ok more smart diff testing needed...
this time i'm gonna take the springs out!!
  Send a message via MSN to shaunjohnson
Urgeoner
Urgeoner's Avatar
02.21.2010, 12:52 AM
*Yoda's voice* "A long journey it was, MC, and the full circle you walked..."
nevermind I'm tired lol
At least the stock chassis are cheap and easy to replace. It was fun reading up with your trials!
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
02.22.2010, 02:14 PM
I run 50k oil in my front diff and 10k oil in my rear diff with no center diff and it is perfect (after trying many different combos)! I also still run Nitro-Revo diffs instead of E-Revo diffs & they are holding up just fine, and I beat the living crap out of my truck! Plus, I hate to beat up on the already beaten up horse, but a properly set slipper will protect the rest of your driveline, diffs included.
For anyone that doesn't already know...you are supposed/need to run thicker oil in the front diff and thinner oil in the rear diff, to help with steering. The thicker the oil is in the rear diff, the more your truck will push (understeer) in the turns and not steer very well at all, which is why you run thinner oil in the rear diff and thicker oil in the front diff. You can even run a spool in the front if you want, but you will get very over-aggressive steering (oversteer) and it will be hard to control...oil in the front diff that is too thick does the same thing.
-Chad
PM ME IF YOU HAVE THE BELOW:
AMorgan
02.22.2010, 02:36 PM
Crash, what rocker posts are you using?
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
02.23.2010, 12:40 AM
I use the stock Traxxas posts, I put a M4X12 mm set screw in them with red Locktite then use a lock nut to secure the rocker. I was tired of trying to unscrew that M4 button head screw and the post would come with it. I got the idea from Lunsdford titanium posts. They are machine with a threaded post on top for a nut instead of a threaded hole for a screw.
No brain, no headaches.
mistercrash
Guelph, Canada, eh!
02.24.2010, 12:48 PM
So you break your last set of rear P2 rockers and you are still waiting for the new sets to come in. What do you do? Leave the truck on the table and wait? I say no way! Take your unused Long Travel rockers, make P2 rockers out of them and keep on bashing or racing.
Putting the broken P2 rocker on top, it might not be absolutely perfect but I would say it's pretty darn close. All the holes line up very nicely.
mistercrash
Guelph, Canada, eh!
02.24.2010, 02:17 PM
I just tried the truck on 6S. I was surprised at how well it worked.
AMorgan
02.24.2010, 03:06 PM
Interesting idea on the stock rocker posts. I have been considering the Lunsford ones, mainly because I already have a bent one and if I'm going to spend the money... My only gripe with the lunsfords is that the nuts are annodized... lock nuts don't work right annodized. I like the idea though.
Chadworkz
Chadworkz's Avatar
02.25.2010, 12:19 AM
Lock-nuts working has nothing to do with being anodized or not...the "locking" part of the nut is the hard rubber insert in the last few threads of the nut. Anodizing has no affect on lock-nuts.
-Chad
Chadworkz
Chadworkz's Avatar
02.25.2010, 12:21 AM
MC, I think you need a set of NIP Hardcore Racing Titanium Rockers, and I just happen to have a full front & rear set! ;)
-Chad
mistercrash
Guelph, Canada, eh!
02.25.2010, 01:37 AM
Remember the Kershaw chassis experiment? Remember how it failed? Remember I had to pay $40 to get a new top plate? I got it today. It's the 2.2 version with 20 degrees kick up in the front and 3 degrees kick down in the rear
yeah those angles are all wrong, they don't match the bulkheads at all. But not to worry as the aluminum is so soft, I can bend the plate to the correct angles with two fingers. What a piece of junk! I'm done with this guy. The plate is not even flat.
squeeforever
squeeforever's Avatar
02.25.2010, 03:04 AM
Chad, if crash doesn't want em, PM me and I might take em off your hands.
brian015
brian015's Avatar
02.25.2010, 08:55 AM
hardcore rockers on ebay
mistercrash
Guelph, Canada, eh!
02.25.2010, 10:09 AM
Thanks Chad but I don't want the rockers, I do fine with the stock ones.
02.25.2010, 12:58 PM
Damn, that chassis isnt all that great for what you pay- what the heck quality alloy does he use, 4xxx series?
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
