Originally Posted by aqwut
I'm sure with 10000 Watts and the proper aerodynamics, the twin 1527 could get you there... but that area you have might not be big enough for that kind of speed run...
Their is a larger area next to it which is the main takeoff and landing strip. We are making our runs on the taxing part.
Here are some quick #'s I calculated....just don't know if they are right.
Single 2215 that I have coming runs max ~172 amps. At 44.4 volts that should be around ~7636 watts or so.
Twin 1527's that I have coming as well run at ~100 amps. At 44.4 volts X 2 that should be ~8880 watts. Is this correct thinking. Both are over 10hp.
