PerformanceRC
10.25.2005, 09:47 PM
The first one 1/8 Shaft. The Shaft bent during startup.
The Second one the windings got damaged, it was used, so maybe it was already weak?
-Jack Miles
2x Warrior 99.18, Hacker Master Car, 2x 7XL, 10L, 8L, 7S. 20.120!
10L's wasted by my Speed project: 2
  Send a message via AIM to PerformanceRC
dabid
10.26.2005, 01:29 AM
Aha! See that nbcaz? Looks like you should NOT buy a BL system used after all!!!
I was wondering why the 6s was in there in the first place, I too would have gone with either a 9 or 10 L. But dang, that car isn't going to weigh anything, and that nutso gearing........make sure you get your aerodynamics right!
Serum
Serum's Avatar
10.26.2005, 01:32 AM
We need movies!!
Dafni
Dafni's Avatar
10.26.2005, 01:41 AM
I'm glad I asked! ;)
PerformanceRC
10.26.2005, 06:27 AM
I'm not sure where you got 6S From. I am running a 6S Lithium Polymer, but since the beginning I have been running 10L Motors.
If the car runs well, there will be movies same day.
-Jack Miles
dabid
10.26.2005, 02:17 PM
Originally posted by PerformanceRC
I did have time at a drag strip, but I had lithium polymer problems. Its running on 6S BTW. Then I bent my motor shaft, but it was a 1/8 shaft and I ordered a 5mm shaft.
This is what confused me, didn't kick in that you can't get a 6s with a 5mm shaft, and I was reading too fast.
