Twin Velineon Brushless
OldSoldier
E-ReVVo/SoldierMaxx
OldSoldier's Avatar
Twin Velineon Brushless - 07.15.2008, 11:23 PM
Originally Posted by Topspeedtimmy View Post
1. 19/52 yields a 2.73 ratio. 20/68 is 3.4 ratio, so it's a much higher gearing. My gearing is 19/62 which is 3.3. 19/52 would be good for a 50mph speed run, may be too high for off-road running.
oops, when I said 19/52 above...that was a typo...I meant 19/62. But thanks for the ratio information above. I used to wonder how folks computed the gear and drive ratios. I can see from your numbers above that its just spur tooth count divided by pinion tooth count. Duh! Sorry, I took electronics, not mechanics. Slap me! (always wanted an excuse to use that emoticon).
So I ended up going the hobby shop and getting a 62 tooth spur and used a 20 tooth pinion.... She was out of control! I don't have a speed gun, but my wheels were complete saucers and I had almost no weight on the front wheels for steering! It was a blast! 150 degrees on the motor 147 on the ESC.
I'll make the wiring modifications tomorrow if I can. Thanks for the tip...something in the back of my mind was telling me I should have done it different...that's why I asked. What you said makes perfect electronics sense.
OldSoldier - Maryland
E-Maxx FLM chassis/combo-bulks, 10XL, Quark 125, 4-6s
E-Revo 6s MMM Medusa 80mm 2200KV 61.7MPH!
OldSoldier
E-ReVVo/SoldierMaxx
OldSoldier's Avatar
07.16.2008, 08:31 PM
Originally Posted by VintageMA View Post
I've been using a 1515/2.5D on 6S for a while now in my E-Revo on 18/62 with Badlands and it is geared for a solid 35 mph. With temps the way they are right now I think I can go up to 20/62 and get closer to 40mph with no problems at all, but I can't see doing any on-road with the E-revo that much and the 35 is a fun speed for bashing around and no parts breakage with lot's or torque at hand.
Vintage,
You don't mention what ESC you are running at 6s???
OldSoldier
VintageMA
VintageMA's Avatar
07.17.2008, 07:33 AM
Originally Posted by OldSoldier View Post
Vintage,
OldSoldier
MMM.
“Everyone has a right to be stupid; some people just abuse the privilege.”
Mamba Max Monsters nowhere to be found
OldSoldier
E-ReVVo/SoldierMaxx
OldSoldier's Avatar
Unhappy Mamba Max Monsters nowhere to be found - 07.17.2008, 10:20 AM
MMM.
Lucky Duck! I can't find a Mamba Max Monster anywhere! Not even on ebay.
OldSoldier
E-ReVVo/SoldierMaxx
OldSoldier's Avatar
07.17.2008, 10:28 AM
2. If you plan on running this reliably you will definitely want to link both batteries in parallel to both ESCs. This will make it so the motor systems get the exact same voltage and run the same speed and will also make it so that the LVC kicks in at the same time for both systems.
I'm pretty sure you need to cut the BEC wire, that's what I did and it runs well. The ESC that is powering the BEC tends to run a little hotter than the other one.
OK TST,
I made the wiring modificatiions last night. I hate soldering those new Traxxas connectors, but I'm getting better at it. I'm going to sneak out of the office and run to a nearby park to test it. Hope nobody comes looking for me
E-ReVVo
OldSoldier
E-ReVVo/SoldierMaxx
OldSoldier's Avatar
E-ReVVo - 07.17.2008, 09:46 PM
OK TST,
Just finished a 10 minute bashing session with my Twin Velineon Revo.
What a blast! I'm running 62/20 gearing and its as fast as ____
I installed a set of fans on my speed controllers and temps are down to 105 for the ESC and 140 for the motors. The E-ReVVo is so fast, one of my tires came unglued! And just FYI, I also installed a set of Tekno anti-sway bars. This is the best performing RC vehicle I've ever built. Its what I've been trying to build from a TMaxx chassis for the last two years without success.
E-revo speed pass (E-ReVVo) Twin Velineon
OldSoldier
E-ReVVo/SoldierMaxx
OldSoldier's Avatar
E-revo speed pass (E-ReVVo) Twin Velineon - 07.27.2008, 09:12 PM
I just did a couple speed passes with a Garmin GPS. With 62/20 gearing I could reach 44.5 miles per hour. I was not using fresh batteries. I have not had a chance to try it with fresh batteries, or other gearing options.
OldSoldier
E-ReVVo/SoldierMaxx
OldSoldier's Avatar
07.28.2008, 09:07 PM
Just did a pass with 22/58 gearing...48.5 MPH still not on a freshly peaked pair of 3s lipo batteries. Should hit 50 plus with fresh batteries.
david lamontagn
07.29.2008, 12:19 AM
Try it mine tonight for the second time on 6s, with a Neu 2.5d, gear 24/62 with the RCM revo hybrid V2 diff, buggy ratio.
It's amazing, i realy love this truck
ReV:-O
RC-Monster Carbon Fibre
08.17.2008, 09:09 PM
Originally Posted by azjc View Post
Flightpower 5000 3s also fit
dont you mean the 4900 3s packs? if so, they are 30mm tall - will they fit?
e-mike
e-mike's Avatar
08.17.2008, 09:45 PM
me too i run 6 cell(4800mah 25c zippy-r) in my bleu e-revo with a 1515 1.5d wow50mph on weelies for a 30 min of fun!!!!
D8t on juice!!
