E-Traxxer
11.23.2005, 01:58 AM
Does anyone know where I can find a 5mm bore mod 1, hardened pinion then? Preferably 10-12 teeth :) I think this truck is just too heavy to have a plastic spur. Im pretty sure it weighs in excess of 13 pounds, my heaviest truck to date!
dabid
11.23.2005, 03:32 AM
Um, here, for one. Go to the storefront site and check out the gears section, I think it's in there.
Serum
Serum's Avatar
11.23.2005, 06:02 AM
Better get a plastic spur!
i thought about this option too, with the FLM ext. chassis and the skid as diffholder.. How is the ballance like this?
E-Traxxer
11.23.2005, 01:13 PM
With 18 cells in the back, the back is a bit heavier. However, if/when I get lipolies this truck should be balanced well.
Dabid, are you sure those are "Hardened" pinion gears? I need a hardened one to stand up to the hardened spur, the plastic spurs just can't handle a truck this heavy!
Serum
Serum's Avatar
11.23.2005, 01:45 PM
get those ofna plastic spurs. they will handle the truck for sure. if you tend to brake one, you can get the delrin machined one. (not needed imo) it's not that heavy... and thos ofna spurs are quite something.
you have got a rather light savage. no gearbox, and allmost no aluminium..
squeeforever
squeeforever's Avatar
11.23.2005, 04:02 PM
somewhere on here i read that if you stip them often try boiling them before you use them. something to do with it making it not so brittle. i think dabid was the one that posted it.
Serum
Serum's Avatar
11.23.2005, 04:04 PM
They are tough as nails already..
dabid
11.23.2005, 09:48 PM
Yeah, I boiled my Ofna 51 tooth spur for 10 minutes before mounting it, but my lehner 2800xl still managed to strip it somehow.....maybe in one of the crashes or something. I can say that it did soften the teeth up a little, because this time most of the gears were laid over instead of full on sheared.
E-Traxxer
11.24.2005, 05:55 AM
Hmm.. looks like I'll boil the next spurs that come in the mail.
Jasper
12.10.2005, 05:21 PM
E-Traxxer, nice savage! I like your center diff and the batterys inside the chassis.
But what is the advantage of the center diff modification? You lost the 2 speed, so will the speed be slower? Did you have to make special drive shafts?
I'm asking this because I have got also an BL savage. But with the 2speed.
E-Traxxer
12.10.2005, 11:01 PM
I used a center diff because I wanted to shed some wieght and be able to fit the batteries inside the extended chassis. Another advantage of the center diff is that it somewhat improves handling, although it is much tougher on the drivetrain because it does not have a slipper. The speed is probably a bit slower than if I used the two speed, but once I get my new BL setup, I won;t be worrying about speed, just a way to handle it!! I'm going to make a center slipper that will replace the center diff and use the strobe slipper, as well as mount the motor more securely. As for the driveshafts, I went to my LHS and loooked at different dogbones. I used the extended dogbone that came with ny chassis in the back, and a rear dogbone from an X-Factor in the front (116mm I beleive).
I also got out for another test run today at my usual bashing spot. I added a motor brace to make sure that the motor didn't move around with the somewhat flimsy mount. That seemed to fix the spur-stripping porblem, but disaster struck, and I stripoped another one. I was coming off of a jump and the nose went up in the air, so I did a quick reverse throttle (thinking that I didn;t have reverse, just brake), and "CCCKKK", stripped spur.
Jasper
01.02.2006, 05:33 PM
Thank you for the information E-traxxer!
But I have got a few more questions. How are the temps of the motor and esc? What gearing are you running? What lipo's are you gonna to use? How is the truck handling in the air?
I'm planning to build a custom chassis with custom TVP's and battery holders, just like the emaxx and revo conversion. I pick up a center diff from a 1;8 buggy. This diff doesn't have a slipper. Can you make this easily? Or is this impossible? And what is exactly a strobe slipper. Because on the 2speed I have got a slipper clutch. So what is the difference between these two?
E-Traxxer
01.02.2006, 05:56 PM
I'm running a 14 tooth pinion and a 51 tooth spur on the 10XL on 18 cells at the moment. The controller gets pretty hot,only the 7020 though, shouldnt have any troubles with the 9920. I'm using some GP3300's right now, but once I finish off my center slipper setup I'm putting in my new 2240 14t on 10s lipoly in there. The lipolies I have are the Maxamps.com 4000 MAH car packs. The truck took a few minutes of jumping to get used to, but once I learned how to jump it, it flew really well, it has pretty even weight distribution, so it usually stays level when I jump it. Since that last update I have taken out reverse on the controller and everything is fine, it runs pretty quick and I'm getting about 20-25 minutes of runtime. If you're using a center diff, you shouldn't really need a slipper, if you want to use a center slipper like something I'm going to use, which is basically just a one gear tranny, you will have to put it together yourself or try the ofna dominator slipper.
I should have the new slipper setup in about a week. I'm currently upgrading the diffs to 6 gear spyders from UE, and after that the only thing I might ened to get is some of the heavy duty dogbones.
Jasper
01.02.2006, 06:21 PM
Aha, I get the slipper stuff now :)
But did you drive the truck also with the 7XL? Because that is the motor I am gonna use.
E-Traxxer
01.02.2006, 06:43 PM
I did, but it ran too hot for the gearing/cells I had. If I geared down lower it would have been fine for use.
