Krawlin
Got brushless?
Krawlin's Avatar
09.14.2008, 01:00 PM
Looks like its coming along good so far Ryan, although I still think you should just leave it a gasser......
And that motor you showed me on AIM is a beast.......
Monster GT Conversion
Takedown
WARNING: May become violent.
Takedown's Avatar
09.14.2008, 01:01 PM
Sounds good. Have you looked into spending a little extra $$$ on A123 cells and making a nice pack out of them. I know a 10,000mAh 25-30C 10S lipo packs would weigh about the same or less then the lead acid packs. Get your self a good ESC that will handle the current loads and your set.
I think Im stuck on PB's because of how cheap they are and how easy they are to maintain. I found a 100a HV ESC on Bidproducts website for $30. Its 10s capable so that should work fine. I will be using Mech brakes aswell.
RIP- Tammy (9/14/08)
Takedown
Takedown's Avatar
09.14.2008, 01:02 PM
This motor?
Krawlin
Got brushless?
Krawlin's Avatar
09.14.2008, 01:13 PM
This motor?
Yeah, yeah, that's the one!
lutach
lutach's Avatar
I think Im stuck on PB's because of how cheap they are and how easy they are to maintain. I found a 100a HV ESC on Bidproducts website for $30. Its 10s capable so that should work fine. I will be using Mech brackes aswell.
Will the PB's handle the current load though. Here is a nice little video to show you how a starting battery pack made of A123 cells does: http://www.youtube.com/watch?v=lyYBh4ec05c. Here you can see that they want to be rich real fast : http://www.tekbattery.com/battery_prices.html. All you need is 4 of the DeWalt packs and do a 10S4P set up. Will pay for itself down the road. A 9200mAh, 36V A123 packs will put out 276A continuous and 552A max if needed and will weigh much less then the PBs you plan on using.
09.14.2008, 01:32 PM
Look at those wimpy wires...
Takedown
Takedown's Avatar
09.14.2008, 02:19 PM
Im already getting the brushed behemoth motor. The 100a HV ESC will also be on my list and the PB's will most likely be my choice. Im on a budget.
lutach
lutach's Avatar
09.14.2008, 02:25 PM
Will the brushless ESC work with the brushed motor?
Takedown
Takedown's Avatar
09.14.2008, 02:26 PM
Thats what Im going to find out. For $30 its worth a shot.
Takedown
Takedown's Avatar
09.14.2008, 02:34 PM
Trying to send you a pm lutach. Empty your pm box.
lutach
lutach's Avatar
09.14.2008, 02:35 PM
It won't work. For that ESC to work with a brushed motor it needs the appropriate software. I have that ESC that was sent as a test unit from Suppo (The manufacturer) and they keep everything simple, so it won't have the software I mentioned. and it won't work at all with a brushed motor. If you're on a budget and try it, it'll be costly as you spent the $$ on the motor and the batteries. If you go with the options I showed you, you'll spend a little more $$$, but it'll work.
lutach
lutach's Avatar
My e-mail address is: brasuca2478@hotmail.com.
Takedown
Takedown's Avatar
09.14.2008, 02:36 PM
What "brushed" ESC would you reccomend that is budget and that will handle 36v?
Takedown
Takedown's Avatar
09.14.2008, 02:40 PM
E-mail sent to your addy. Please check lutach.
