squeeforever
squeeforever's Avatar
11.27.2005, 10:47 PM
yes, i think he is running a schulze that has a limit of 18.
-corey
coolhandcountry
coolhandcountry's Avatar
I run a 18.97 schulze. if you really want something to get down and run long time. think of a 12xl on 8s lipo. My schulze dont hardly get warm. The 9xl is being run on a 7020 in a monster gt but I don't have room for my 10 cells packs i made up. I may try to re configure them. but time will tell. you have so many options mack. I my self like the 19 series a little better. the 22 series would be even more power ful.
this is what I think. IF you want to go fast. You want long run time. Money is the object. If money is no object you can go 60 mph and 30 min run time. It is your choice.
Peace!
Country
Help support the
Rc-Monster
Buy here
mack
mack's Avatar
11.27.2005, 11:11 PM
Money is a object because i have to buy everything
I just orderd my new charger
Ultra Duo Plus 30 - Graupner +
Schaltnetzteil 13,8V / 20 A - Graupner
And i bouhgt the conversion kit
This is the shoping list that i still have to buy
1xHPI aluminum shocks NR: A712
2xHBdiffcups NR:C8019
1xHPI bearing 8x16x5mm NR B085
2xspider gear NR: 87193
1xHPI Heavy Duty 2-Speed NR: 87227
motor???
controller
Ubec
accu's
So the motor setup may cost me a max of say 600dollar
That means controller Ubec and motor.
E-Traxxer
11.27.2005, 11:20 PM
With $600 for the BL system, you could get a 2250 or 2240 motor on 20cells with a 9920 ESC..
mack
mack's Avatar
11.27.2005, 11:37 PM
Yeah i now but it's not much faster and my run time is much less
(correct me if i'am rong)
E-Traxxer
11.28.2005, 12:06 AM
A 2250 on 20 cells would fly! You could probably get 50 MPH like promod did on "cold" (low) gearing.
coolhandcountry
11.28.2005, 09:05 AM
get a good controller and a 9xl run it on 20 cells if you don't like it buy you the 2240 or 2250 and run. I have not ran a 2250 yet. but hopefully I can get it on the truck with the next couple weeks. I am going to a center diff like promod. I can let you know then what i think more of this set up. I can say that if it runs close to my 1930 as far as size to power ratio. I am going to be very happy rcing dude.
Peace!
Country
Help support the
Rc-Monster
Buy here
mack
mack's Avatar
11.28.2005, 10:44 AM
If the 2240 or 2250 is the beter option i would be beter of buying that one directly.
So that i dont have to spend 100 dollar on a wanderer 9XL
I now that the 22 serie would be more expensive but is it WORHT IT!!
Or do i get a littel more speed but my run time would be max 10 or 15min.
Serum
Serum's Avatar
11.28.2005, 01:46 PM
yeAH, get a 2250, and a 36120.. it will be a blast!!!!
no need for it though, balancing your needs. Like i told you about 10-15 times by email allready....
a 9XL on 20 cells will reach the 50-55 mph as well.. how fast do you want to go.. If i where in your shoes, i would get that 9XL with 18 or 20 cells. a 9920 would be the controller of my choice as well. like i said earlier, you have got NO idea what 2000 watts of brushless power is capable of.
mack
mack's Avatar
11.28.2005, 02:01 PM
I don't want another controller I want max 20 cells but if a
lehner 22 serie is much beter. (I don't now this)
50 or 55 mph is fast enough.
But does it have the same torque/runtime
I don't care if it's costs 200euro more if it's worth it.
coolhandcountry
11.28.2005, 02:04 PM
I do know. I like it to :D Hey a 9xl on a 9920 witha 20 cells is pretty kick butt. I have ran 18 cells. I wanted to try a 9xl on 3695. Get the one with no limit and 24 cells and let it fly.
Is the lehner 19 and 22 series better than the wanderer. Yes i think so. It has higher and tighter clearances. you know just a little more quality. The 22 series takes a special motor mount. If you want to spend the money for some kick butt awesome power. I won't stop you. Don't jump in with both feet if you don't know what you jumping in. A 1950 will mount to a xl motor mount. 3695 with out the 42000 rpm limit. a 1950 12 turn on 24 cells may be what you looking for. Lipo would be better for lighter weight and more voltage.
Peace!
Country
Help support the
Rc-Monster
Buy here
mack
mack's Avatar
11.28.2005, 02:12 PM
That's also a good idea coolhand to get that controller,
then its beter if i want more speed inthe future;)
Gustav
Gustav's Avatar
11.28.2005, 02:13 PM
Torque is in excess anyway with the xl motor,only get a 22 series if you're very fond of rebuilding transmissions of an evening.I'd say get a 1950 if you want the high end motor.
@serum,why is it you don't recommend the hi-amp versions?I think the quoted kv is the same for both but the non-high amp can be configured for a lower kv.
When i ordered my 1950 i ordered the hi-amp,was this a bad move?
Serum
Serum's Avatar
11.28.2005, 02:15 PM
Okay...
listen to this;
if your batteries can push out 2000 watts, the max output of your motor is 2000 watts minus the losses.
A 2240 on 20 cells can drain this 2000 watts from your batteries, but SO is the 9XL... it will be a matter of efficiency, and if it differs any, it will be a percent or 2 maximum.
The 2240-2250 have got segmented magnets, and to keep a very long technical story short; they perform better at partitial load. (get less hot) BUT since the 9XL is not a high KV motor, it will not too hot either. AND you can get a heatsink for that motor as well, from MIke..
All and all, i don't 'just' reccomend you that 9XL, it is a balanced mix of price vs preformance.
mack
mack's Avatar
11.28.2005, 02:23 PM
Okay chekt SERUM but what about what coolhand is saying.
maby thats the beter option go whit the 9XL on 20 cells and wen i want more i can go to 24cells
Sound nice to than i can upgrate in the future
