Well guys I decided to abort the lst2 4-stroke conversion because of clutch mounting issues and decided to go brushless instead. My setup will be the following...
ESC- BidProducts 125-150a 7s
Motor- KB45 8xl
Battery- Four 3s 2800mah 30c packs "Two 2800mah packs in parallel which makes a 5600mah 3s 30c which will be paired in series with another Two 2800mah 30c packs wired in parallel to make a 5600mah 3s 30c to make a 5600mah 30c 6s pack." Hope you guys could understand that.
Ill see if I can get some new pics up once I get home.
