View Poll Results: Do you want new switches
Yes 76 84.44%
No 14 15.56%
Voters: 90. You may not vote on this poll
brushlessboy16
brushlessboy16's Avatar
04.24.2009, 06:58 AM
Kind of defeats the purpose of a switch then..
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
04.24.2009, 07:23 AM
ive mannaged to foil the switches evil habbits
mount the switch on your car so that it is laying flat (on it's side) AND the switch moves horizontally to the cars body.
this works amazingly well...bacuase think about it...
the main G-force you get is gonna be from a nose on or a flat land....the only way the switch can turn off in this setup is if you land sideways hard on the wheels...
and all cars have a tenancy for the diff to stabilise it in hte air...so ive noticed that you rarely land on your side hard off a jump...
ive never had a switch turn off on me ever from doing this
  Send a message via MSN to shaunjohnson
Patrick
Patrick's Avatar
04.25.2009, 02:04 AM
You still use the switch normal, you just slide the piece of lexan out of the way when you want to turn it off.
twisted8
04.27.2009, 01:51 PM
ta_man
04.24.2009, 10:39 AM
I think the switch they should use is the type that comes with many radios for the receiver pack (like a Futaba Radio). It is much bigger than the current switch but is very sturdy and reliable.
brushlessboy16
04.27.2009, 05:51 PM
At the track this past sunday, there were two guys running Mt with the MMM in there vehicles... One was a Savage flux and the other was a standard e-revo converted to Brushless... Both encountered problems with their switches and put them out of the running..
I went to radio shack and bought a MicroMini Toggle switch for 2 bucks, its much better then the stocker and is much harder to foul and flip. By the end of the day one mamba switch was decapitated and buried (literally )
JerryC
05.01.2009, 01:22 PM
does replacing the switch void the warranty?
05.01.2009, 02:42 PM
Nope. Patrick from CC has said that mods are allowed as long as nothing is soldered (or unsoldered) to the actual ESC circuit board.
slash_48
slash_48's Avatar
05.02.2009, 11:55 PM
I don't use the switch cut it off and solder problem solved.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
05.03.2009, 05:31 AM
Mmm sparks! You must go through connectors like crazy.
Unsullied_Spy
Unsullied_Spy's Avatar
05.03.2009, 05:37 AM
It will slowly wear away at the tips of your connector. I've never had to replace a connector due to wear If you're bashing just cut off the switch when it goes bad, if you're racing get rid of it before you race unless you want to shell out the $ for a nice covered switch. I'd rather keep the cost of the ESC low and get a bad switch (life really does go on without it) than have to spend more for something I really couldn't care less about. If you want a switch, spend the money and do it your way.
shaunjohnson
i pwn nitro
05.03.2009, 04:54 AM
hows this for an idea....anyone here ever used a VXL ESC??
the crappy traxxas ones?
well you know how they turn on..one touch of the button...i reckon we need that...it's a "soft off" setup that uses just a micro momentary on button and you press it once and it's on then press it again and it's off...i forgot what exactly that setup is called but anyway...yah...that'd be a good idea :D
shaun
Hockeyplaya20
Hockeyplaya20's Avatar
05.03.2009, 07:07 PM
i agree, my very first run i flipped the truck on its lid, the switch moved just enough to turn it off
in fact, right now im putting on a new toggle switch :)
6s MMM E-Revo l Rustler VXL l Stampede XL-5
05.05.2009, 09:14 PM
Aye, this is a forum, not a mobile phone- full sentences and punctuation never killed anyone..
I've never had any issues with my switch, but then I've never had any issue with my V1 either
I like the idea of jumper though, like the little ones on the back of cd-rom drives (you know what I mean). If you could incorporate that onto the pcb in a suitable location so that it protruded from the top/side of the esc case, then one could simply remove the jumper part to turn off the esc, and replace it to activate it- the spring tension would hold it in place fine, and it could be tethered so as not to become lost.
05.06.2009, 05:41 PM
Whats that got to do with the switch though- if you forget to turn the switch off after removng the batts, next time you plug the batts in (without turning the radio on first since due to old age you forgot?) the model would still turn into a run away regardless of there being a switch or not...
Rule #1 in the R/C world is to turn the radio on first, and off last, every time. Funny thing is though I swear the MMM has a built in failsafe of sorts anyway- if I turn the tx off and leave the batts plugged in & esc turned on, the esc leds go to a different color, to indictate 'no signal' and returned the throttle to neutral.
So, switch not required in that sense....
