Byte
05.09.2009, 06:46 PM
Just one question about that software... I downloaded it a few minutes ago, but how should I install this thingy on the MMM? O.o Or do I just have to put the MMM with the USB on the pc, and then it's done?
EDIT: I can't install the software? He wants to download .net framework or something, but he says wrong size blablabla? I'm using windows XP. Help please?
q8-maxx
E-Maxx Lover
q8-maxx's Avatar
05.09.2009, 07:24 PM
download the .net framework its free then you should install the cc software
MMM v1 zippy 2x3s 5000mah neu 1y 1/8 diff's
MMM v3 Rc-monster 2x2s 5200mah-HC medusa 36-70-2300kv
Pic's - video - youtube video's
e-mike
e-mike's Avatar
05.10.2009, 11:32 AM
other issue with the new soft(well i think)....i installed my mamba max in my hyper7 and i run it on 3 cell lipo...2300kv 70mm medusa...so everinthing run perfectly( foward-brake-backward ) but afer 6 minute the esc wont go backward..its make a sound but refuse to move....goes foward and brake but wont goes back....i thinked that my esc was dead(its a brand new)but no i reinstalled the 1.20 soft and this issue is gone...
my set-up
hyper7
medusa 2300kv 70mm
zippy 30c 3 cell
fasst 3pm
mamba max-lowest timing-BEEP DISABLED-punch control 50%,
D8t on juice!!
Maciolus
05.10.2009, 11:58 AM
I have just finished racing with SW, MM and MMM. With new firmware those systems seem to be more powerfull. Strange
> HB L2PE + MMM + Medusa 60-1600 @ 6S A123
> HB LSP + MMM + Medusa 70-1600 @ 6S2P A123
> AE B44 + MM + Medusa 50-3300 @ 4S A123
> AE J82 + SW 5700 @ 2S LiPo
> AE TC5R + MM 6900 @ 2S LiPo
big greg
05.10.2009, 12:50 PM
yea i put in on my MMM and 1y in the truggy and MM and tekin 2650 and both are smooth, i like the adjustable auto lipo
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
05.10.2009, 03:10 PM
I just installed it yesterday. The auto lipo adjustable cut-off was all that I could ever ask for. Thanks Castle!
Note to those who are getting more power after the update, the timing on my esc seemed to have reset itself to normal despite the fact that I had it set to 0 before the update. Timing adjustment is now displayed under the advanced settings tab.
Area 52 Ranch Raceway
T.R.C.R.
Helly
Helly's Avatar
05.10.2009, 04:02 PM
Will the "auto-lipo settings" detect the number of A123 cell?
If it work for A123, the auto lipo adjustable cut-off can be a really good add for A123 !
snellemin
2 KiloWatt RACER
snellemin's Avatar
05.10.2009, 05:22 PM
You don't need a lipo cutoff for A123's. But if you want to, just use the custom setting and set it for 2V per cell.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
Helly
Helly's Avatar
05.10.2009, 05:54 PM
One of my A123 pack seem's bad just coz of a wrong cut-off setting...
i always switch 4S to 5S or 5S to 7S and i am not always near a computer to reprogramme it...
So if the "auto lipo cut off" detect A123 cell, it ll help! ^^
Pdelcast
Pdelcast's Avatar
05.10.2009, 06:09 PM
A123 auto cutoff is slated for the next release -- right now the Auto Lipo is only for standard Lipos.
You should set a "custom" cutoff for the A123 cells.
Patrick del Castillo
President, Principle Engineer
e-mike
e-mike's Avatar
05.10.2009, 06:47 PM
so after reinstalled the new soft everything going flawlessly...anyway my issue was due by a wrong setting in my txso the controller seem to better understand the motor at low speed,,less cogg and i really love the option DISABLE THE BEEP!!!..and now when i go backward and apply trottle to go foward im able to stop the truck slowly..
now its time to have the mm pro for testing this new soft
D8t on juice!!
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
05.10.2009, 08:58 PM
* Improved low speed operation, detects and escapes cogging better
* Bug fix: Rare instance where throttle was applied and controller would stay in idle
These 2 improvements will be awesome. That bug used to happen almost regularly on my savage and every time it did I would s*** my pants as I would think the controller had died again. It would work after releasing the throttle and trying again but I would always check the car over when it happened and I could never work out what was causing it.
Smoothness improvement will be nice as with the feigao startup wasn't always silky smooth. The medusa was better on startup.
Kcaz25
Kcaz25's Avatar
05.11.2009, 10:11 AM
I've read the firmware beta info... and I'm confident that it will work in my standard setup. I installed the software and will be up and running as soon as my last parts come in this week. I will post the results...
badassrevo
05.11.2009, 11:17 AM
No harm installing it on a MMM V1?
It runs so good now I don't want to chance anything going wrong.
I can't imagine anything smoother than my MMM V1 and Neu 1512/2.5d.
e-mike
e-mike's Avatar
05.11.2009, 11:19 AM
go dont be afraid install it...you will be surprise
D8t on juice!!
