Byte
02.16.2010, 08:24 PM
The major choice here depends on the budget that you are working with. Over in the UK you have access to Festool equipment which is one of the best in quality for Eu. I found that they are also one of the most expensive in most cases. Like you stated there are different levels of quality which only you can decide at what level you wish to work with. For my own taste I try to get something that is of the best quality that I can afford with whatever budget I am working with. I dispise having to use something of crapy quality so I try to go for fairly high quality, which usually equates to higher pricing, but then I know it will last a long time and give me the best work possible.
As said, I want to spend about 100-150 dollar. I'm 16 years old, got an very expensive hobby and some other things in my life to spend money on, so I can't/won't spend $1000 on a drill press which I will use once a month...
Normally I would go for quality, but I haven't got 1000 dollar laying around
Any idea what will be 'good' (good enough) for me?
whitrzac
Can't catch this...
whitrzac's Avatar
02.16.2010, 08:56 PM
if your only doing light work, you can look into a dremal drill press....
what he's trying to say is, "buy the best one you can afford, and you won't regret it later"
