rckcrwlr
Where are the Rocks????
rckcrwlr's Avatar
04.18.2011, 02:34 PM
Originally Posted by Dj_Sparky View Post
Could you snap a picture or 2 of how you did it exactly? :)
Front:
Rear (Both sides)
Bought my Wife a Rock Garden :027:
Dj_Sparky
04.18.2011, 03:49 PM
Awesome. Thanks a lot!
NickRummy
NickRummy's Avatar
06.21.2011, 03:38 PM
How's this going John? Just picked up a savage roller with TCS conversion to work on :D
rckcrwlr
rckcrwlr's Avatar
06.21.2011, 03:41 PM
Nick,
You'll love it. I just ordered paddles all around for my trip to the dunes of MI.
Can't wait. Only issue I had was my slipper burning up. Fixed that with a set-up from Kershaw Designs.
NickRummy
NickRummy's Avatar
06.21.2011, 03:46 PM
Nice! Are you using a steel spur or plastic? Are you still running the stock flux motor? I just posted a thread with my project.
rckcrwlr
rckcrwlr's Avatar
06.21.2011, 03:47 PM
Here you go...
Working with my buddy Dan from Kershaw Designs, he hooked me up with a Slipper bearing set up that is designed for high voltage RC's.
The set up is two washers with bearing in between. The key to the design is the concave washers on the outside that keep constant resistance on the bearings and nut.
I took it for a quick run last night and she is alive.
rckcrwlr
rckcrwlr's Avatar
06.21.2011, 03:50 PM
Steel spur and stock motor. Haven't had issues with heat. I see you are running wider tires. I'm running 5B Trenchers. The tread is harder and narrower but they are heavier than what you are running.
thzero
06.21.2011, 03:53 PM
Yeah I run (or ran) the same KD thingamabob... just cinched it down tight.
NickRummy
NickRummy's Avatar
06.21.2011, 04:01 PM
Actually, that's just what came on the roller I got. I'm using the 5SC wheels and tires. Got halfway through putting them together on lunch break today. I'm hoping today to have the wheels and tires mounted on the roller so I can get an idea of track width.
rckcrwlr
rckcrwlr's Avatar
06.21.2011, 04:04 PM
You are going to need the 24mm hex adapters for the Baja Wheels...
NickRummy
NickRummy's Avatar
06.21.2011, 04:10 PM
Got em sitting on my desk. Question is, do I need to get XL stubs.....
thzero
06.21.2011, 04:11 PM
Those are good, but they suck because of Savage axle design. Nick knows about my solution, since he did them for me, so I would highly suggest that. Yes you lose a tad bit of width, but its a much studier solution (I posted it in my thread about my 5T here at RCM). I went through at least four axles where I busted it at the end of the threads; rather expensive.
NickRummy
NickRummy's Avatar
06.21.2011, 04:16 PM
Oh crap, is this Chris?! How's it going man! I'm hoping to work on a newer design that'll give me more width......
thzero
Yes, and do my customization using the BAJA 24mm hex hubs that came with the 5SC.
rckcrwlr
rckcrwlr's Avatar
06.21.2011, 04:18 PM
Haven't had issues with mine yet...must not be beating it hard enough.
