Thread Tools Rating: Thread Rating: 32 votes, 4.94 average. Display Modes
snellemin
2 KiloWatt RACER
snellemin's Avatar
08.09.2010, 02:43 PM
Naah, ik ben een Surinamer. 250km is quite a distance for sure. And gas ain't cheap either.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
VZW
08.09.2010, 03:01 PM
How is this deal?
CLICK These are the right ones right?
VZW
08.09.2010, 03:09 PM
Okay just realized that it is the GX I need to be looking at. The ones I linked to are of okay wattage but I don't know that they will be as easily converted.
Nard Cox
n00b
08.11.2010, 08:08 AM
Yesterday evening I bought myself 3 of these, they shipped this morning.
They look pretty identical to the one in this thread BUT I've just found that the one in this topic has model nr : 321632-001 and the ones I've bought are : 338022-001. Hopefully it will work *fingers crossed*. I will let you know :)
Bmr4life
08.13.2010, 02:12 PM
Nice. I did the same with two old server power supplies I got free from work. They're only 32a, but I only need one to get max wattage to my 208B.
Nard Cox
n00b
08.13.2010, 02:35 PM
Originally Posted by kazuaki View Post
The reason I can leave the jumper in place is because I added a power switch to the input side.
So far, it seems to work well...
Any pics on how you did that?
I received my three PSU's today. All three work flawlessly. :)
How do you shut down the PSU, just by pulling out the power cable? The fan makes a noice that is freaky loud ... definately need a solution for that. The PSU itself is also WAY smaller than I expected, even when I knew the dimensions...
Will post a pic tomorrow, going to solder some leads and stuff now. Thanks for the tip, this saved me a nice buck.
Metallover
RC-Monster Spudgunner
Metallover's Avatar
08.16.2010, 10:15 PM
I got mine up and running last week... Thing sounds like a hair dryer! Prank your roommate by putting it in the bathroom for awhile!
It would probably be possible to open it up a little bit and use multiple quieter fans.. I might have a go at it.
Thanks for the post snellemin!!
Nard Cox
n00b
08.17.2010, 04:00 AM
The three victims:
Opening it up:
The noisemaker:
Possible solution?
I tested the PSU's shortly with my EOS0615i Duo2. When charging a 4S 5A pack with 5A/1C the voltage is at ~12.35, when I put it at 10A/2C the voltage drops down to ~12.17v and I will only charge at ~9.75A, any ideas? I saw snellemin's stay at 12.8v @ 25.4A:
Naah, I haven't bothered opening it up. I wanted something simple and cheap. A regular ATX is too much work compared to this PSU. I will ask at work if boosting the voltage is even feasible with this PSU. I have no schematic of what the other pins do. I was pulling 25A last nite out of the PSU and the charger stated 12.8V@25A. When I get a few more, I'll open one up.
snellemin
2 KiloWatt RACER
snellemin's Avatar
08.17.2010, 04:06 PM
Mine might be a fluke man. As long as it works right.
Nard Cox
n00b
08.17.2010, 04:17 PM
True, but I though it was strange that it only charged at 9.75A and not 10A ... Oh well I will empty some packs soon and try charging two 4s 5a both at 10A/2C.
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
08.19.2010, 02:33 PM
Pardon me if I seem ignorant, but is there any way to use those power supplies to build something as powerful as this.
http://www.rivergatedist.com/bulldog_90.htm
I had a Rivergate PS years ago and I loved it. It was a 30 amp model which was perfect at the time. But although they are really good and powerful from what I remember, they are way too pricey.
No brain, no headaches.
snellemin
2 KiloWatt RACER
snellemin's Avatar
08.19.2010, 05:00 PM
Sure you can, but you will have to wire them up in series, which is dangerous if you don't know what you are doing.
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
08.19.2010, 05:33 PM
You can also look at one of these - HP DL580/ML570 G3 Power Supply 1300W Watts Power Supply
Photos below taken from rcgroups:
Alien
mistercrash
Guelph, Canada, eh!
08.19.2010, 09:13 PM
I don't know what I'm doing so I won't go that route
stampy
stampy's Avatar
08.20.2010, 10:43 AM
I was thinking of wiring 2 of the 47amp power supply's up. I'm no electrical engineer, so how would your house hold 120 volt circuit handle almost 100amps of power? arnt most circuits in a house only 15amps?
