ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
09.16.2012, 11:59 AM
i emailed Green Bee and told them their data is wrong (and asked about the status of my replacement charger). at this point, i'm even questioning whether the controller is Kelly or not. i have too much to do outside today to tackle getting that out and tearing it open, so that'll have to wait.
i agree about the SLAs...i'm not looking forward to the performance dropping when it gets cold here, but i have no choice at this point. getting that ping pack is going to be $1700+ (upgrading to a 7.5A charger), which is more than i paid for the dang scooter itself ($1250). i agree it needs to be done, and the biggest plus is that i can bring the ping pack inside to charge. inside to work, so i can use their juice. :) i should have enough by spring to get the ping pack.
Eflite Blade 400 heli on 3s
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
09.16.2012, 08:43 PM
Almost 17 months ago, I calculated how much using a 2004 Toyota Sienna was costing me. When the price of gas went over the $1.30 per liter mark and stayed there, including insurance, upkeep and all expenses related to running this car, the total came to close to $375 per month. And that's for a car that was paid for so there was no monthly payment. So by not using it at all (because I sold it to get the scooter) I save $375 per month. Thinking of that money in my pocket, a $1700 battery doesn't seem that expensive. It all depends on how you look at it and how dedicated you are on using this scooter. If it's just a toy to play with then maybe keeping the SLAs is better. If it becomes your only means of transportation to go to work (like I do) then you want the best of everything so that your ride is as much fun as it can be. So before you buy anything, sit down and ask yourself what was the reason to get this scooter. Once you honestly know the answer then you'll know what you need to do. Have fun with it.
No brain, no headaches.
ClodMaxx
ClodMaxx's Avatar
09.16.2012, 10:26 PM
while i plan to use it to work as much as possible (even through the cold), it's not replacing my Z. the only thing that can do that is a new 370 Z.
ClodMaxx
ClodMaxx's Avatar
09.18.2012, 10:08 AM
i just looked at these on ES... if the specs are true (or even close to true), it seems like a better option. i could configure the same setup as what's in it currently (five 12v packs wired in series) and have 36Ah instead of ping's 30Ah. plus the heavy protective casing (i hit some pretty big bumps along the way to work. still trying to find the least-bumpy line).
2 problems i can see:
-it almost seems too good to be true (and you know what they say about that). with all 5 cases plus the cells, i suspect the weight is way off
-i wouldn't be able to take the cells in at night when it's cold.
anyhow, more options than just ping and cell man. (i got an email back from cell man giving a quote. 16S 2P A123 20Ah Pack 1 50V 40Ah 40A BMS $1490)
mistercrash
Guelph, Canada, eh!
09.18.2012, 07:48 PM
Too good to be true indeed. Those are starter batteries for ICE vehicles. They are not meant to be used in an EV. They are not 36Ah, they are 36Ah SLA equivalent. Which means a bit more than 20Ah. No BMS to monitor each cells to prevent over charge or over discharge or equalization during charging. Maybe you can get one of those LiFePO starter batteries to shave a few pounds off the new 370 Z you're going to get.
ClodMaxx
ClodMaxx's Avatar
09.18.2012, 10:26 PM
i just got another response from Paul (aka 'cell man' at ES) that he can build 60v 40Ah split packs. that's what i'm going to get come spring. it may fry my controller, DC-DC, heck maybe even my motor. but i'm gonna have a heck of a smile on my face as it goes up in flames
ClodMaxx
ClodMaxx's Avatar
09.22.2012, 11:58 PM
i tore the scoot apart to get to the controller, opened it up, and was somewhat pleasantly surprised at what i saw. 80v caps!
i found no writing anywhere to indicate whether it was a kelly controller or not. but it does look solid enough to go possibly up to 72v.
ClodMaxx
ClodMaxx's Avatar
09.23.2012, 03:22 PM
i just made my first official mod, lol. when i flip the turn signal switch, it made this loud, screeching beep that only turned off when i turned the turn signal off. well, this little sucker was responsible for that. ripped it off the circuit board, and no more beep when the turn signal is activated.
