squeeforever
squeeforever's Avatar
06.07.2006, 11:42 PM
I'm pretty partial to flames as well. Maybe stripes behind the flames.
Sneeck
RC-Monster Custom
Sneeck's Avatar
06.08.2006, 12:46 AM
Is there enough clearence on the front wheel to steer? Cause it don't look like it will clear the shell when you steer.
I dig flame's myself, but if you can't paint it stay with somthing simple like the 1 or 2 straight line's in the center. Or you could always find some inside decal's.
overtki11
overtki11's Avatar
06.08.2006, 01:38 AM
keen eye dude...but the shell will be raised a little to clear , once i get the front body mounts done as well....(only got the rears done so far)
coolhandcountry
coolhandcountry's Avatar
06.08.2006, 08:16 AM
http://www.jackalhobbies.com/
here check this place out. I got some from them the other day.
I love the way the look. I just got to get them on there right.
They go on different than the last ones i did.
Peace!
Country
Help support the
Rc-Monster
Buy here
overtki11
overtki11's Avatar
06.08.2006, 11:15 AM
hey thanks for all the input and ideas dudes....appreaciate it.....
i'll have to decide soon......i'll let you guys know the outcome soon...cheers!
Sylvester
Sylvester's Avatar
06.08.2006, 01:38 PM
Either way, i bet you will have a sweet looking truck in the end! And its not somthing that costs a ton of money to change, too.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
overtki11
overtki11's Avatar
06.09.2006, 05:24 AM
i guess you're right...if i goof up i can always try again....:002:
overtki11
overtki11's Avatar
06.09.2006, 05:28 AM
Originally Posted by MetalMan
LOL, thought you knew that :). I was just cutting some earlier, and will be cutting more. I do it with my shop-vac secured to my scroll saw, and cut with the shop-vac on so that it will suck up the dust from the garolite and not get into my lungs.
This stuff is rough. I can only go about 10" (254mm) (including turns) before the blade on my scroll saw is too dull to cut with! I've gone through 3 blades already!
dude, you seem to the the most well informed bout this stuff, so i'll ask you...
does G10 come in black? or any other color for that matter?....
Batfish
Batfish's Avatar
06.09.2006, 08:25 AM
I believe the short answer is "yes".
Go to www.mcmaster.com
put "G10" in the search
Click the link for G10 Garolite Sheets
Scroll down on the right to see the colors they have.
Good luck!
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
MetalMan
MetalMan's Avatar
06.09.2006, 09:28 AM
Ya, it does (as Batfish pointed out). I got my G10 from McMaster, and in the quantity I ordered it only came in the greenish color. If I had ordered a different quantity I could have gotten it in black. From McMaster, you can get black G10 as long as the sheet size is 12 x 12 or larger.
overtki11
overtki11's Avatar
06.09.2006, 10:58 AM
thanks for the super speedy replies guys!......:027:
overtki11
overtki11's Avatar
06.12.2006, 01:50 AM
weekend bash got rainned out...AGAIN!!!
so i thought i'd be brave and pick up my lexan shell, masking tape, spray cans....
and rattled the cans a bit....
and....opened up the can..
and...
and...
painted the "cage" instead!!!
the "cage" is officially done! :sweat:
MetalMan
MetalMan's Avatar
06.12.2006, 08:39 AM
You didn't happen to get those countersunk washers from McMaster, did you? If so, it may be worth it to check the screws for tightness every once in a while, since the washers will bend inwards.
That black looks really good! Can't wait to see the finished product.
overtki11
overtki11's Avatar
06.12.2006, 11:44 AM
oh...them silver washers?? i got them from a LHS who sells ofna 1/8 buggies...these are from the new "hyper 8"
....that make two of us! i can't either!:019: :035: HAHA
overtki11
overtki11's Avatar
06.14.2006, 09:25 PM
well,...apart some mismatched mounting hardware....i guess the chassis is complete.....
even managed to solve the front shock mounting points :D
still got painters' block though....:035: :035:
