wallot
wallot's Avatar
02.09.2007, 04:44 AM
Thanks to mild winter i run my maxx almost every Saturday. Once weather gets better I will have it in my car and run it after work on BMX track on my way home.
I actually enjoy building maxx and stuff around. There are still couple things I want to change except new batteries:
FLM Shocktowers with 1/8 scale threaded shocks
Want Nomadio React radio with all the sensors
and maybe new suspension arms
And after I am done I will probably start building a new truck - either LST or Revo
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
 Send a message via ICQ to wallot
wallot
wallot's Avatar
02.10.2007, 06:23 PM
Even with 14 sanyo cells and 3.3 diffs the car is insane. Was running 51/18 gearing and all that nitro guys said was "wow". I cant imagine it with higher quality cells (with 18 cells and 1/8 diffs) the top speed should be about the same). Unfortunately front bulkhead and arms did not like one bad landing :)
Well next time i'll be running with the FLM hybrids and RPM arms are on their way.
Radek
*EX-10 Eurus*
jnev
jnev's Avatar
02.10.2007, 06:35 PM
Thats what happens when you bash hard, but it is all part of the fun.
Serum
Serum's Avatar
02.10.2007, 06:36 PM
too bad man! these things suck.. you managed not to pull your pillowballs thru the knuckles?
glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.11.2007, 02:29 AM
Wallot
Not trying ot bust on you... but I tried to make a thread to post pics etc of my stuff so it's not all over the forum. ;)
I think I need to work on a website and just link to that... does that work good for anyone? I have seen a few guys do that but I tcan't think of too many guys here that have websites or pages with their stuff.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
wallot
wallot's Avatar
02.11.2007, 08:05 AM
Originally Posted by glassdoctor
Wallot
:) from you first post "Maybe others can do the same" i thought its a thread for others to post pics so the forum is not full of tons of pics threads :)
Radek
*EX-10 Eurus*
glassdoctor
TEAM FUSION
02.11.2007, 02:31 AM
I did a little racing today... it was good and bad... and had some fun.
I have a short video clip to show... just have to decide where to post the info.
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
coolhandcountry
coolhandcountry's Avatar
02.11.2007, 10:24 AM
I like that you are using the truck. Nice.
Peace!
Country
Help support the
Rc-Monster
Buy here
glassdoctor
TEAM FUSION
02.11.2007, 11:42 AM
No problem wallet... just having some fun ;0
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
glassdoctor
TEAM FUSION
02.19.2007, 01:41 AM
Thanks... you need mod1 pitch pinions.
www.rc-monster.com has some as does starluck-rc.com
also you will find some made by Century, the r/c helicopter company.
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
steve671
02.19.2007, 03:46 AM
Thanks.
I am using a Mamba 5700 motor which has a 1/8 inch diamiter shaft. It appears that all they have availible that works with the metal spur gear is 5mm bore. Do you know of an adapter or sleeve to make the 5mm bore pinons work with the 1/8 inch shaft?
Thanks.
Serum
Serum's Avatar
02.19.2007, 07:56 AM
Shoot Mike an email, i think he can make an adapter for you.
glassdoctor
TEAM FUSION
02.19.2007, 10:43 AM
Yeah.. I think he has had some 1/8" bore mod1 gears before...
EDIT: woah... you are using a MM5700 in a 777? That motor is way too hot (too high kv) for a 1/8 buggy and it's undersized too. It will run but it will get very hot.
You can try it but watch the temps and see what happens... I think you will be picking up a new motor very soon. And it will have a 5mm shaft... ;)
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
steve671
02.19.2007, 04:05 PM
It will be running on 11.1v li-po. If I gear it very low, do you think I will still have problems?
Serum
Serum's Avatar
02.19.2007, 10:54 AM
12,13,14 and 15t should be available in 1/8th bore any time soon. But that motor is a concern indeed!
