captain harlock
RC-Monster Captain
captain harlock's Avatar
03.08.2007, 01:05 PM
I have it. It's good, but it thermals alot, although I used it in a 2wd 10th scale buggy( very light) with a 1920/8 and 10 GP3300mah. I even used a 12v fan and even that did not help alot.
IF, you are gonna use it with a 540 sized motor, then you probably need to feed the motor with lots of volts to cut down the amp draw. Even Mike Franz, an official of Kontronik's technical department, said that it isn't really made for use in cars, despite the fact that it has two types of car programs.
I found that it thermals alot when you apply brake more often. Probably if you use mechanical brakes, that'll keep the controller much cooler. Either than that, this thing is smoooooooooooooth.
Nice to meet you!
Aragon
03.08.2007, 02:27 PM
Shucks. I hope it doesn't thermal. You're not the first person to tell me this though. I will be running 10S to minimise amp draw and hope that will be sufficient. At 30V (3.0v/cell) and 65A, that's 2000W - well within its ratings. I thought about getting an MGM controller, but the Kontronik is cheap enough to risk it. I'm into RC helis too and I know the Jazz will be useful for a future heli if it ends up on the shelf with this experiment.
Glad to know it runs smoothly. I've read old posts about it cogging. I guess that was with old firmware. Cool!
captain harlock
RC-Monster Captain
03.08.2007, 02:34 PM
It coggs because its not strong enough to handle a motor in a rc car.
Make note that this thing only gives a 55amps continuous and 65-70amps surge. It isn't really a good choice for MTs.
Nice to meet you!
starscream
RC-Monster TQ
starscream's Avatar
03.08.2007, 03:05 PM
In my experience, my lower amp esc work's most efficient with an appropriately geared automatic 2 speed transmission. For example, I have an esc that runs most efficent at ~35amps. The pwm kicks in after ~50amps or so but I don't notice the pwm kicking in when I use an automatic 2 speed tranny like the tmaxx or Revo trannies. Now, if I put this same esc/motor in my single speed losi 8ight the pwm kicks in very quickly as the amps spikes are much higher with the single speed so I am no longer considering using this esc for the 8ight. I plan to get some eagletree comps once I get my G2R back together. The auto two speed tranny is a great load buffer but you do sacrifice a percentage of the instant power capability of the higher amp esc's.
Ha Ha
The Flashlight Strikes Again...
BP-Revo
BMW M Power!
BP-Revo's Avatar
03.08.2007, 06:19 PM
I hope it works for me too. :p
I might tweak with the controller and adjust the subtrims or something so that the "neutral" the ESC will see when my throttle trigger is between neutral and full brake is just infront of full brake, but not enough to engage throttle (like in the little dead-band spot in between).
We'll see. My CRX seems to be very good about holding EPA adjustments properly.
starscream
RC-Monster TQ
starscream's Avatar
03.17.2007, 05:50 PM
Here's a must get for your CC HV setup:
http://www.rc-hydros.com/pistix.html
Thanks goes to Serum for the link
Ha Ha
dogboy
03.10.2007, 06:56 AM
yes simple ohms law. P=VI. 500wattts=50voltsX10Amps or 10voltsX50Amps. You get my drift.
03.10.2007, 05:12 PM
Gotta remember the resistance factor in there...
50v will only draw 10A if the resistance is 5 ohms. 10v will draw 50A with a 0.2 ohm load. Both do generate 500w.
Serum
Serum's Avatar
03.10.2007, 05:41 PM
Yes, that's the reason for a HV setup being more efficient.
03.10.2007, 05:48 PM
Yeah, I just want to make sure some people realize that simply adding more voltage on an existing setup will just increase current. You need to increase the motor winds quite a bit when you increase voltage if you want less current.
Aragon
03.10.2007, 08:15 PM
and/or regear ... :)
BP-Revo
BMW M Power!
BP-Revo's Avatar
03.10.2007, 06:46 PM
Yea, for ~40,000RPM, I need a 20 turn 1530 motor, which is dang high (way higher than I had ever expected). But it should fly :D
BP-Revo
BMW M Power!
BP-Revo's Avatar
03.10.2007, 11:37 PM
Not exactly...no amount of regearing will change the fact that most motors lose efficiency above 40,000RPM.
Serum
Serum's Avatar
03.11.2007, 03:00 AM
who said it runs above 40K?
And a setup with 85 percent efficiency can draw less current than one with 95 percent efficiency..
Aragon
03.11.2007, 04:30 AM
Why do you say motors loose efficiency above 40k RPM? Which motors exhibit this behaviour?
Motors run most efficiently when iron losses and copper losses are equal. Copper losses increase as torque load increases (current goes up), while iron losses increase when RPM increases.
Obtaining maximum motor efficiency is a balancing act of seeing how much torque you need, and running your motor so that its RPM is high enough to deliver the required torque after gearing and low enough to achieve an equal balance between iron and copper losses at these torque levels.
In e-heli world, high performance setups are chosen so that motors run just below their peak RPM where heat buildup increases exponentially due to iron losses. At that point the motor delivers the highest torque after gearing before copper losses become too high.
