starscream
RC-Monster TQ
starscream's Avatar
08.21.2005, 03:34 PM
This should eliminate the one-way and lock the tranny into second gear, effectively making it a single-speed transmission.
Sorry, missed this part. coolhandcountry has a good point. Depending on the design of the gear, brakes and reverse may not be favorable. They will probably work but not be as efficient.
Great idea Dafni, a center diff would be the best single speed option IMO.
Ha Ha
The Flashlight Strikes Again...
Dafni
Dafni's Avatar
08.21.2005, 03:38 PM
Yes, it's a great idea. Many people think of this.
Sometimes, when I'm lucky, a whole happy day passes were I don't think of a center diff for my Revo. This is really naggin at me!
starscream
RC-Monster TQ
starscream's Avatar
08.21.2005, 03:46 PM
LOL
Don't know if anyone's seen this thread but I am working on duplicating this on my revo. I will be using a mugen mbx5 differential. This might work in the 2-speed MGT or the EMAXX tranny.
Here's the link:
Revo Center Diff
Ha Ha
Dafni
Dafni's Avatar
08.21.2005, 03:59 PM
Interesting link!
Starscream, did your first version work well?
starscream
RC-Monster TQ
starscream's Avatar
08.21.2005, 04:19 PM
V1 was a single speed center diff which was geared too high for my motor. This version would work well on a larger slower motor.
V2 used the two speed tranny along with the center diff which worked well but added too much material and was too heavy IMO. V2 was a big step forward but I believe V3 will be much more effecient with less material and weight.
V3 will be very similar to the linked thread but I will be using steel drive cups and dogbones and keep the tranny backwards for rear brakes.
I'll update my own thread when V3 is finished.
Cheers
Ha Ha
Batfish
Batfish's Avatar
08.21.2005, 04:54 PM
After another trip to the garage and some tinkering, I think the center diff will be the way to go. I'll need to figure out dog bones to finalize it. That should be the only thing I need to order once I figure out which to order.
Here's what it would look like from the top - the red spots are where I would have to cut out the chassis to accomodate the spur (about .5cm on each side).
Image hosted by Photobucket.com
Here's a view facing to the front of the MGT:
And one facing to the rear:
I'll need to make an aluminum mount to hold the diff braces, then another to hold the motor.
The only dog bones I have laying around are the OFNA ones in 83mm and 92mm. With the 92mm one set up in the rear, I would need a 117mm dog bone for the front. Essentially, I have 210mm-ish to work with for two dog bones.
I found OFNA part 36110 that's 88.45mm and HPI part 86058 that's 123mm. I think the two of them would work together and since they're both sets of two I'd have a couple extras.
While I figure out the further details of the center diff I'll still use my modified MGT tranny and see how that works out :)
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
Waxxxymunkee
I've learned so much here
Waxxxymunkee's Avatar
08.21.2005, 05:24 PM
WOW man Much credit to you guys i have been on here just an aww of all your creations I would like to know if anyone has a BL truck for sale but again i love watching you guys work on your stuff utterly amazing :eek: :eek: :eek: :eek: :eek: :eek: :eek:
" If you hear me coming I did not do my job right "
coolhandcountry
coolhandcountry's Avatar
08.21.2005, 05:44 PM
Hey batfish what about two 105 shafts. They ue titanium. Just a thought. May help may not.
Peace!
Country
Help support the
Rc-Monster
Buy here
El Jarretto
08.22.2005, 11:41 PM
Nice project, now do it as cheap as possible so I can laugh at Patrick in his computer face!
Promod
08.23.2005, 02:24 PM
If you need custom length driveshafts try www.RCalloys.com
He makes some very nice driveshafts.
Thank you,
Promod
Batfish
Batfish's Avatar
08.23.2005, 06:00 PM
Mike's putting together an order for me and I'm getting the plans worked out to mount the center diff.
Unfortunately for me, I sprained my shoulder last night so I've got a busted wing for a week or so. No serious work for now.
Joe
Dafni
Dafni's Avatar
08.23.2005, 06:12 PM
Thank you,
Promod
Or you could ask Mike;)
Joe, I hope it's not too painfull. Get well soon!!
El Jarretto
08.23.2005, 09:28 PM
That sucks man. Get well soon. I think you should shoot for under $500 including li-po's and a charger. (I know you already have a charger and li-po's) This way I can prove to extremely ignorant Patrick that he can convert his MGT for under $500.
Batfish
Batfish's Avatar
08.23.2005, 09:43 PM
I'm not sure who Patrick is, but I can already show how to make this for under $500, provided you can get a roller for $200ish. If you've already got the MGT, you can even do batteries and charger for under $500 (nimh - or a little more for lipo).
I'm using a $195 controller, $80 motor, and a $25 steering servo. If you've already got the servo, you're under $500. You may need to spend a couple hours and $10 at Home Depot to buy an aluminum elbow bar to make your motor mount, but no additional drilling needs to be done (to the chassis) for that.
If you don't convert your tranny like I did you'll need the brake servo. You can lock your tranny in forward and drop the reverse servo regardless (unless you want reverse).
Keep in mind, my conversion is for racing - not for top speed. Chances are that my MGT will not reach more than 30MPH once completed. That's fine with me since I can't get up to that speed on my track anyway :)
For a top speed truck you'll need to spend a bit more on batteries and use a different motor than I use.
Once I get this completed, I'll see about doing a full write-up to making a brushless MGT out of a stock MGT.
And thank you folks for the well-wishes :)
Joe
coolhandcountry
08.23.2005, 10:12 PM
I sad to hear your incedent there. Hope to see get back to normal asap. How that center conversion coming so far?
Peace!
Country
Help support the
Rc-Monster
Buy here
