MetalMan
MetalMan's Avatar
06.22.2008, 03:52 PM
Thanks!
Soon I'll be throwing an AX-10 front axle on because my front narrowed Wheely King axle can't take the abuse, and the AX-10 axle is only 1/4" wider than my narrowed WK axle.
10.28.2008, 06:34 PM
A bit off subject, but I was wondering what it takes to use maxx sliders as center driveshafts? Main issue is that the ax10 axle and the pede tranny have 5mm output s and the maxx sliders are 6mm... I have seen it done and wonder what people did to make it work...
I like the body-less crawler, looks cool!
MetalMan
MetalMan's Avatar
10.28.2008, 09:40 PM
Thanks!
Obviously it's been a while since I updated this thread, but the crawler is now running AX-10 axles front and rear with an Airtronics 780 steering servo. The front diff gears are the hardened ones for the HPI MT2 (same ratio as stock) and the rear diff ring gear is stock, while the rear diff pinion gear is from a Wheely King.
These diff pinion gears look like this:
http://www3.towerhobbies.com/cgi-bin...4&I=LXJYM2&P=K
There is a hole in the diff pinion gear for a screw pin to go through it, just like you will find on the Maxx/Revo/Savage/Rustler/etc. The shaft diameter is 5mm.
Now see here:
http://www3.towerhobbies.com/cgi-bin...?&I=LXDDT2&P=7
That T-Maxx transmission output yoke has a 5mm inner diameter, as you will find here:
http://www.traxxas.com/PDF-Library/4910-08_tranny.pdf
The yoke is made to fit shafts with flats on them, so you have to drill out the yoke with a 5mm drill bit to make sure it will fit onto a 5mm round shaft.
Then you can use a regular Maxx driveshaft (4951X if my memory serves correctly).
As for the transmission, you can use the same yokes, but you'll have to shave down the end so it won't interfere with the transmission case.
10.28.2008, 09:59 PM
Originally Posted by MetalMan View Post
Thanks!
Now see here:
Good info, thanks!
MetalMan
MetalMan's Avatar
10.28.2008, 10:16 PM
Comparing the Maxx shafts to 'Pede/Rustler or stock AX-10 driveshafts, Maxx driveshafts win hands down .
10.28.2008, 10:26 PM
I figured that, I have had some issues on my cr-01 with both the stock driveshafts (redefine the word "suck") and pede sliders. I have some homemade brass collars that work well, but the cr-01 has steep driveshaft angles, is geared for 10mph, and runs a novak 13.5... bit too much power!
I will see if the lhs has the 4927x yokes. Hope so, as that would make my like simple...
