rchippie
rchippie's Avatar
09.14.2007, 12:39 PM
Originally Posted by GriffinRU View Post
I am working with Mike on Brass-Copper heatsink for Quark, updates will come pretty soon :)
I haven't seen nor touched his controller, so I do not know yet.
I thought we did the estimate with you before.
Thank's artur for the heatsink update. Whats your opinion on the heat spreader for the quark, copper or aluminum ?. Artur how have you been ?.
REAL MEN RUN BRUSHLESS
GriffinRU
09.14.2007, 12:55 PM
You welcome!
For Quark:
- use stock alum housing as external heatsink
- replace both alum internal plates with brass
Challenge:
- very tight inside
- galvanics, is it a problem? :)
- soldering...
lutach
lutach's Avatar
09.17.2007, 10:36 AM
I just heard from the engineer and he is having some trouble with the software. This is what he asked me: "We need to know when the brake apply. For example, to what exactly position you turn the trigger will just free the motor and to what position you turn the trigger will apply the brake." I told him that the brake has to be proportional with the trigger and it should not be applied when the throttle is at neutral. I know there is the "ms" things and I have no clue what they mean and if they could help them at all. Any inputs will be appreciated.
snellemin
2 KiloWatt RACER
snellemin's Avatar
09.17.2007, 10:53 AM
I have a question. Just for kicks, would a mamba esc "brain" board work with the your mega esc? That would be a nice mod as well.
But as of the neutral position, could dragbrake be applied at that position?
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
lutach
lutach's Avatar
09.17.2007, 12:40 PM
I thought about that when I saw the photo of my ESC, but I think it might be a little comples as the Mamba uses a different MPU.
MetalMan
MetalMan's Avatar
09.17.2007, 01:06 PM
My guess for "ms" is milliseconds. The transmitter sends out throttle pulses of 0-2ms long, depending upon the position of the trigger. 1ms is neutral. For airplane radios, I believe 0ms is neutral (since they don't have reverse).
Xtremespeed
09.28.2007, 06:42 PM
Anything new yet? I got my Neu 1512 1.5d yesterday, and now my motor temps are down where they should be, but my MM is hot, hot, hot. I can get it over 200 running short bursts for about 2 minutes in my living room. Defiantely time for a new controller. Let us know how your project is coming.
lutach
lutach's Avatar
09.28.2007, 07:26 PM
I was hoping it would be done a couple of weeks ago, but the engineers had trouble with the car software. I will give them a call tonight to see what is going on.
Serum
Serum's Avatar
09.29.2007, 05:11 AM
Great work Lutach!
though the proportional brake seems to be a PITA to all the engineers. Did they took an existing design and simple added a bunch of FETT's?
lutach
lutach's Avatar
09.29.2007, 10:28 AM
Originally Posted by Serum View Post
Great work Lutach!
I got some help from someone in the rumrunnerracing forum with the information the engineer was looking for. The design is very much like the Schulze 40.160 controller, but it seems like a simple design compared to the Schulze.
lutach
lutach's Avatar
09.29.2007, 01:51 PM
Bad luck is just raining on me this month. The engineer said he is really having trouble with the car software. He said he can have the airplane version delivered right away. I can't have that, mainly because he said he could do the ESC for cars. Maybe I just jinxed myself on this one. This is just one of the problem I was worried about. The good thing is that all the controllers are done, but they just need the right software.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
09.29.2007, 02:07 PM
Well, don't give up... this has been a common obstacle for all BL companies. Some are still trying to get good software after several years of product.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Xtremespeed
09.29.2007, 08:12 PM
Well put. Keep the faith man. We need something better.
lutach
lutach's Avatar
09.29.2007, 09:01 PM
I wish I had learned Programming and Electronic Engineering when I had the chance.
lutach
lutach's Avatar
12.17.2007, 08:17 PM
I like to keep you all posted on the situation with the 200A controller. I asked the engineer to make 4 200A controllers, but he used sample boards and the unit(s) that was tested failed. Now I told him that is completely messed up since he said he could do a 200A car controller. He feels better doing a 100A controller, but I asked him to make a few 100A and some 80A and 60A controllers. I'm also waiting for another company to send me one of their controllers so I can test it. This one seems nice. It can use sensored and sernsoless motors and should come with a program box. Now the messed up part with this one is the fact that I missed the first delivery attempt on Friday and now it's past 7PM and I'm not sure if the driver will even show up today. I called UPS and they told me it's up to the driver now if he wants to deliver or if he wants to go home. Oh well, I hope it gets here LOL. I have attached a picture of the controller for you all to see.
Name:	New BL ESC.jpg
