Re~Mix
ĄGo Baby Go!
Re~Mix's Avatar
07.26.2005, 07:53 PM
Wow, well if you can actually get that much money out of somebody then go for the chassis.
RC18T FT - Quark Castle Creations Airtronics IB
  Send a message via AIM to Re~Mix
Shadow350Z
Shadow350Z's Avatar
07.26.2005, 10:22 PM
but but but isnt the g3 race suspension more expensive??
ehh i need the chassis anyways mine right now is all messy cuz of the HV
  Send a message via AIM to Shadow350Z
Shadow350Z
Shadow350Z's Avatar
07.27.2005, 12:58 AM
Serum!
i got a Q
you see the pic i posted on page 3??
I was wondering wut the 2 black thin tube like thingy that came with the kit???
thnx
Sneeck
RC-Monster Custom
Sneeck's Avatar
07.27.2005, 04:53 AM
Aren't those pin's for your wheel adaptor?
Shadow350Z
Shadow350Z's Avatar
07.27.2005, 12:53 PM
nope the pins are silver not black and they are longer than those black ones
squeeforever
squeeforever's Avatar
07.27.2005, 01:48 PM
the black ones are for your wheel adapters the silver ones are for the joint in the cvd.
Shadow350Z
Shadow350Z's Avatar
07.27.2005, 02:06 PM
so it goes in the hole in the axle to put your hex on??
squeeforever
07.28.2005, 04:07 PM
yes
Shadow350Z
Shadow350Z's Avatar
07.30.2005, 11:49 PM
uhh
i wanna get these...
Fat Boy Motor Mount Lunsford
will they fit the HV maxx??
cuz the ones that came with the HV are already stripped i have to use pliers jus to take it off
are these longer and will it damage the HV motor??
titanium is stronger right? and wont strip?
Serum
Serum's Avatar
07.31.2005, 04:57 AM
Just take a close look, if the screws are not too long, it might damage the motor permanent
I just use 10.9 M3 screws to tighten the motor to the plate. And be sure to use a proper key to tighten and loosen it.. Most of the time, those screws get stripped from using the wrong size or poor quality keys.
Shadow350Z
Shadow350Z's Avatar
08.09.2005, 02:52 AM
if i get deans plugs
which solder should i use??
deans racing solder w/ proflux?(do i still need to get flux by trinity?)
or get novak silver racing solder and trinity flux??
Serum
Serum's Avatar
08.09.2005, 01:13 PM
I use silver containing solder for those things..
Shadow350Z
Shadow350Z's Avatar
08.09.2005, 09:36 PM
deans are silver racing solder w/ proflux
does that mean i dont need to get flux no more??
Re~Mix
ĄGo Baby Go!
Re~Mix's Avatar
08.09.2005, 11:34 PM
Nope, you still need flux. Sure you could solder without flux, but then the connections would just fall apart. Seen it first hand.
Shadow350Z
Shadow350Z's Avatar
08.10.2005, 04:23 AM
so if i still need flux which would be better?
Novak silver racing solder or the deans one?
