abiye
11.05.2007, 10:38 AM
if your front tires are ballooning too much you want a thicker center diff oil... i don't know whats in there now but go higher...
btw... what are your run times like?
lutach
lutach's Avatar
11.05.2007, 11:39 AM
Alright, "F" the insurance companies. Most of them tries to milk money out of us anyways. In my BPP truggy, I tried a center diff, but the power my truck is producing it wasn't helping with basically all the power unloading on the front tires. I installed the solid center in again and it is just much better. It handles better too. I can do wheelies again LOL.
2FastSS4U
RCM Brushless Savage
2FastSS4U's Avatar
11.05.2007, 02:47 PM
What do you mean by a "solid center". And I'm getting near 30 mins of runtime, pretty impressive IMO. Also why would I thicken the center diff oil instead of the front? I'd like equal power to be dispersed to the front and rear, maybe a little more power in the front but not as much as it is currently, the fronts turn into frisbee's trying to grab the ground, its pretty funny to watch.
The wisest mind has something yet to learn. (George Santayana)
lutach
lutach's Avatar
11.05.2007, 03:16 PM
Ofna makes the following: 10230 DIFF. LOCK LUBE http://www3.towerhobbies.com/cgi-bin...?&I=LXNXJ0&P=7. The solid center is also made by Ofna here is a link of the photo: http://www3.towerhobbies.com/cgi-bin...&I=LXBZN2&P=SM
It lets you put the power equally to the front and rear. If you unload that much power on the front, your gears will be toast in no time, just like mine.
2FastSS4U
2FastSS4U's Avatar
11.05.2007, 03:29 PM
Would I be able to use that locker with my hotbodies center diff?
lutach
lutach's Avatar
11.05.2007, 03:48 PM
Yes.
2FastSS4U
2FastSS4U's Avatar
11.06.2007, 08:20 AM
OK I'm about to purchase some new wheels and tires since my front two are toast. What should I get? And can anyone explain offset for me, does a half inch offset wheel widen the width of my car a total of 1" or does it shorten it? Also I'm looking into getting 40series wheels, does this require a gearing change and is there a special CA glue that will keep my tires stuck to the wheels as I used medium dynamite brand on the last set that split. I'm looking at Maximizer beadlocks with a half inch offset and proline badlands as one option the other is Proline Wabash 23mm 40 series wheels with Big Joe's, masher's, or Moab's. Anyone had any experience with these 40 series tires if so please help. Thanks, -Steven
nl12
nl12's Avatar
11.06.2007, 08:33 AM
Maximizer beadlocks with a half inch offset and proline badlands, get them in black I have them and they look awesome, tape the insides and they wont balloon. The offset will widen it, both sets of wheels you listed will widen the truck.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
11.06.2007, 09:13 AM
The badlands rock. I did notice mine just starting to balloon today and my engine sucks (Mine aren't taped). That sounds awesome. I can't wait for mike to put the parts up in his store to do this conversion. No more problems like today, smashed fuel tank even though, how well are your batteries protected from shock tower flex? You don't really have to worry about it though having alloy towers.
Forgot to mention. That's great news to hear that you don't have to sell and even better that you got to run the truck.
11.06.2007, 12:56 PM
Parents are great, especially when they are experienced with certain things- always turning to them for advice when I encounter something new that I have never had to deal with before like that. The truck sounds like its a blast- taping the wheels is a good idea, and I recommend normal loctite superglue; just dont get any where you dont want it = most evil substance known to man....
2FastSS4U
2FastSS4U's Avatar
11.06.2007, 02:15 PM
What kind of tape do I use on the inside of the tires? I wish proline offered the ribs or radials on all of their tires, especially for high powered apps., not just for their racing tire line. I'm not sure about the shock tower flex, I dont think its much of a problem as everything fits very well and is tight, I'm a fairly good driver and I kinda stay away from dangerous obstacles, so the batteries are pretty safe and well protected, even if they do somehow get punctured I dont have to worry about it exploding like normal Li-po's & Li-Ions as from what I saw on the apogee website they can have a drillbit drilled through them and barely even smoke and not be volatile at all. He was actually holding the pack right after he drilled through it, its pretty amazing. And yeah Neil I'm very greatful to have my parents help me out especially in situations like this, my Dad is a very good negotiator and 95% of the time gets things his way. One more thing, if I do get 40 series tires are they less susceptable to ballooning?
nl12
nl12's Avatar
11.06.2007, 02:36 PM
I use clear duct tape, I turn the tire inside out, wash it and put 1 wrap of tape around it with about 3/4 inch overlap at the end, then I turn it right side out. 40 series baloon a lot too.
lutach
lutach's Avatar
11.06.2007, 02:43 PM
Fiberglass reinforced tape works good too. I have racing tires on my BPP truggy and they balloon like any other tires. Companies have to design tires with brushless power in mind now LOL. I also like to tape my foam inserts. I use a sand paper to sand the part of the tire and wheel for better adhesion. I use thick CA to hold everything together and let it dry overnight.
11.06.2007, 05:34 PM
CA = Cyona-acryrilate AKA loctite, it sticks everything to everything, so use sparingly....
lutach
lutach's Avatar
11.06.2007, 06:01 PM
I have found that simple tire CA (glue) doesn't hold that good, for me. When I decided to try "thick" CA, it made a big difference.
