BlackedOutREVO
11.23.2007, 10:31 PM
Originally Posted by ssspconcepts View Post
So the actual diff cup is the same size as the 1/8 scale diffs?
Not positive there....
But I think its smaller
ssspconcepts
ssspconcepts's Avatar
11.23.2007, 10:52 PM
Thanks. I ordered my truck a couple of days ago...just curious what to expect.
rchippie
rchippie's Avatar
11.24.2007, 01:38 AM
No they are not the exact same size . All the big beval gears are shaved down . They are the same size in diameter as in a 1/8 but are thinner ( shaved down ) . So they have a shallower cup, but not by much.
REAL MEN RUN BRUSHLESS
ssspconcepts
11.24.2007, 09:49 AM
Got it...Thanks.
ssspconcepts
11.25.2007, 10:14 PM
One more question...what would be a safe bet for gearing on the CRT.5 assuming I was using 2S, MM, and Neu 1509 1.5D (4500kv)?
rchippie
rchippie's Avatar
11.25.2007, 10:31 PM
I dont know , because this is my first time converting a crt.5. someone else will have to answer that for you.
ssspconcepts
11.25.2007, 10:45 PM
Thanks Hippie...maybe Brian or one of the other seasoned vets will pick up the question and run with it.
I hope you got your wheel situation squared away (or should I say rounded away)....
rchippie
rchippie's Avatar
11.25.2007, 10:54 PM
Yes id did get it figured out. Who ever said i needed the FR wheels was right. So im going to get either traxxs rims or rpm rims. I also thought about using the B3 wheels that come with the kit. But if i do that the tire width when mounted will be a 1/4 inch narrower. I have to buy new foams because the acetone i used to soak the tires of the wrong rims split one of the foams. so im going to buy firmer foams because to stock foams were extremely soft.
ssspconcepts
11.25.2007, 10:58 PM
I like RPM rims...I use Rit clothing dye to color them to match my paint scheme...works like a charm and looks great.
rchippie
rchippie's Avatar
11.25.2007, 11:13 PM
I've been using rit dye for years .
Good News
rchippie
rchippie's Avatar
Good News - 11.27.2007, 10:18 PM
I just completed my crt.5 & took it out for it's first test run. It's a quick little sucker . They are very responseive compared to the bigger cars & trucks. So far im vey happy & excited about it. Im going to fully charge my lipo's tonight & give it another shot tommorow. Pics to follow.
What color springs is everyone running ?. I have the stock gray right know but i think i may need the blue medium springs, because of the weight of the lipo.
rchippie
rchippie's Avatar
11.29.2007, 05:53 PM
I started having issues with my new MM today.When i pulled the trigger the car would take off, then it seemed like it would cut on & off rapidly i tried reprogramming it that did not help. So i called castle Thomas helped me diagnose the possible problem. After checking it with another motor it did the same thing. so he said the esc was the problem . So he is sending me a new one. This was only the second time i used it. He also said that usually if a esc is not going to work properly it will usually happen in the first couple of uses.
11.29.2007, 06:46 PM
Thats jolly sporting of them - I've just had to send two MM and a ubec into them for service :(
But the up side is the last one i sent in is on its way back! :)
rchippie
rchippie's Avatar
11.29.2007, 07:13 PM
It really is. they are sending me a new MM without me having to send my bad one in first. they are also including a pre paid postage label for me.
11.29.2007, 08:05 PM
CC is nice.
