Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Kcaz25
Kcaz25's Avatar
10.24.2012, 01:19 PM
Hey Neil and thanks yeah I should take a picture. It's not the can endcap for the stator its those metal pieces at each end if the rotor. Rotor caps. It will come off. Here is what I am thinking. They are just there to add rotor balancing paste to. This end happily does not have any of that paste.
10.25.2012, 06:06 AM
Not sure I understand the diff question. Pics? Sounds like you need a BFH. (Big Fricken Hammer)
Kcaz25
Kcaz25's Avatar
10.29.2012, 09:57 PM
This is perhaps worse than I thought. However the magets so the rotor does seem to be keyed. I think I can tell that now. So hopefully it won't slip but may play back and forth. But should not the brass tubes keep that in check.
The BFH worked on the diff. It's good now what about this rotor?
Zack.
10.30.2012, 09:09 AM
I'd suggest some green locktite to fix that back in place permanently. The little brass tubes / shims should stop the rotor moving back & forth, though even then they will still move slightly, maybe 1-2mm ( most people report the same thing when enquiring about it from what I've seen ).
Kcaz25
Kcaz25's Avatar
10.30.2012, 05:10 PM
Im pretty worried about this still even with green locktight. I did have an extra rotor(the orginal sale price of $25!!) But I gave it to my cousin. I may be getting that back soon!
I think I know what caused this. One day I had to use a lot of pressure to get a pinion off. I think it used to much. The pinion actually did come off but I think it weakened the grip the rotor had on the shaft so that this last time I worked the pinion off it broke the grip completely with little effort. All that to say this was probably the pinion in combination with me in regard to the fault and not Castle.
Also i am not sure in my case that the brass tubes or shims will stop the shaft because the whole shaft is 5mm and could come out through a bearing hole without taking the motor apart!!
I am working on a lot right now and will have an update soon!!
-Zack
ps thanks neil!
10.30.2012, 08:57 PM
Green loctite will do the trick, I guarantee it. Just move quickly, as it sets up fast, have everything ready.
Loctite auto corrects to lactate. Isn't that fun?
Kcaz25
Kcaz25's Avatar
10.31.2012, 09:43 PM
Kcaz25
Kcaz25's Avatar
11.01.2012, 10:43 AM
So the copper strip is keyed the old green glue is too alittle. Should I clean this? What should I do. I got the green locktite
Kcaz25
Kcaz25's Avatar
11.01.2012, 05:09 PM
I think I just nailed it!! I was so anxious to do it right! I ended up cleaning everything off the shaft! Including the copper strip. I mounted it back though of course and with that same green lock! I had to clean out that slot that the copper strip inserted into first. I did this with the point of a razor blade I then laid the razor blade flat to scrape out the old green glue in the two big slots. I covered those locations in green lock already have my pinion stop ready I grabbed the rotor and very quickly slid into until it stopped necessarily at my pinion stop. I had to make sure the strip went into the grove on the inside of the rotor aswell! done! I will test it tomorrow!
Kcaz25
Kcaz25's Avatar
11.02.2012, 08:29 PM
All is as it should be! Tested it a couple of hours ago! Thanks for the help
-zack
Emaxx_Quebec
Emaxx_Quebec's Avatar
11.03.2012, 07:30 AM
So zack, are you going to run a 1717.
Nice job with your motor.
Fred
Kcaz25
Kcaz25's Avatar
11.06.2012, 10:59 PM
Thanks Fred! I will not be running a 1717 at the time. Maybe sometime.
Kcaz25
Kcaz25's Avatar
09.14.2016, 10:21 PM
I am gearing up to finish. The next update is going to be major. I am heading to the machine shop tomorrow. :D
As a teaser here are the truck's newest shoes. Billet ALUMINUM 40 Series 23mm hub wheels, 40 Series Big Joes, and 40 Series Bowties. I found solid 23mm hexes that mount like regular truggy 17mm hexes. They mount unlike those wretched Proline 23mm hexes. I also have some VTR Calibers that I need to clean up. They are truggy tires. They are what I use most. I don't think that they weigh half of what these Big Joes weigh.
Kcaz25
Kcaz25's Avatar
09.14.2016, 10:22 PM
George16
Supermaxx
George16's Avatar
09.17.2016, 01:43 PM
Nicely done Zack. Damn, it's been awhile since I posted. My 9 year old daughter is getting me back into RC so I'm building her a kyosho ST RR Evo electric conversion. Just bought some battery straps, tray and kyosho motor mount a couple of weeks ago.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
