jzemaxx
04.01.2008, 11:51 AM
Off topic real fast. jzemaxx, you signature show a Neu 1524, do I read that right?
Yup that is right. As I understood its a comp motor running 1527 guts but casing it right between the 1521 and 1527, but it has a KV of 1750 I believe. Fits perfectly as far as KV's are concerned.
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
lutach
lutach's Avatar
04.01.2008, 12:31 PM
How did you get it? The guys in the boat forum are still waiting to get one and so am I. That thing must be awesome.
jzemaxx
04.01.2008, 12:34 PM
When did you order yours?
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
lutach
lutach's Avatar
04.01.2008, 12:55 PM
I actually didn't order one yet, because I don't know if it really exists. I did a search in rcgroups and I found that a lot of the plane guys are waiting for one as well. Have you posted pictures of it next to a 1521 and 1527? I would love to see how it stacks up next to them.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
04.01.2008, 11:23 PM
what's the size difference?... I'm waiting for 2x 1527's now....
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
Getter Robo
RC Monster Fiberglass
Getter Robo's Avatar
04.02.2008, 12:10 PM
Did anyone already mention the new Kontronik Jive HV/LV ESCs? They're basically improved Jazz's and the HV versions can handle up to 12S!
Tesla 4 president!
aqwut
aqwut's Avatar
04.02.2008, 11:28 PM
what kind of amps can that thing handle?
othello
HV basher
04.03.2008, 05:23 AM
The spec sheet can be found here.
They did not rate it yet for burst current. The smaller one is rated for 60A cont and the bigger one for 80A cont. The product description in german states that whith proper cooling they are able to provide up to twice the amount of Amps continouus (120 or 160A). I guess burst current may be 20% higher off those doubled values. Theoretically those ESC should be able to push a 1:5 rc car (5.5 and 7KW continouus with 12s Lipo and 3.7V per cell).
Judging from my eagletree records which show Amp peaks of up to 120A on the Jazz 55-10-32 i run (speced for 65A burst), i have no doubts about their statement that those continouus Amp values are minimum values (which can be doubled with proper cooling).
2 interesting features on the jive series ESC: they are waterproof and do have an integrated switching BEC up to 12s lipo. Small downside. Only forward with brakes (no car mode with reverse).
captain harlock
RC-Monster Captain
captain harlock's Avatar
09.03.2008, 08:01 AM
Hello guys!
Although the thread is a bit old, I've got excited about the Kontronik 55 controllers.
I've got a MBX-5T truggy and I want to use 2x 4s 4900mah FP packs( 8s in total).
I'll use my old 1950/10 motor.
Gearing will be something like 17-20 pinion teeth over the standard spur size of the truggy( sorry, I don't know what's the size of the spur).
Will the Kontronik be able to handle this setup?
I might use additional cooling and so forth, but I need something to handle the truggy with some level of effeciency?
Nice to meet you!
lutach
lutach's Avatar
09.03.2008, 08:28 AM
Originally Posted by captain harlock View Post
Hello guys!
Hi Al,
I think the stock spur is 48T. With 8S I would first try a 13 or 14T pinion just to see if the Kontronik will handle the load.
othello
HV basher
09.07.2008, 05:39 PM
As your motor will spin at almost 40000rpm with 8s you should start with smaller pinions as Lutach already suggested it: 12, 13 or 14.
With a 13 tooth pinion your cars top speed will be around 40mph.
Differential Ratio: 4.6
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 13
Total Voltage: 29.6
Motor KV: 1333
Tire Diameter (inches): 5.6
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.017
Spur/Pinion Ratio: 3.54 : 1
Total Ratio: 16.27692 : 1
Tire Circumference (inches): 17.59 inches (446.86 mm)
Total Motor Speed: 39456.8 RPM
Vehicle Speed: 40.39 mph (64.87 km/h)
Estimated Adjusted Speed: 38 mph (61 km/h) - 5% loss
Effective KV Value: 1333
Here is a video with the shortest gearing (1:12,13) i used with the Jazz 55 (with 10s1p A123 around 30v and 30000rpm at full speed) and the corresponding eagletree graphs: whole run, 1 minute in detail, speed passes. There was no cogging but i sometimes noticed a very small delay (say 0.2sec) when starting from a stand still and hitting full throttle. I still use a small heatsink "glued" to the Jazz 55-10-32 cooling plate.
With better cooling mods RC-helicopter flyers push this small ESC up to 4KW.
