Sammus
Sammus's Avatar
04.29.2008, 03:25 AM
Why don't manufacturers just give their cell internal resistance. Wouldn't that solve all these under rate over rate, no standard for C rating nonsense? I always though a cells internal resistance would ultimately determine its discharge capabilities. Could you say anything about the temperature of a pack in given conditions from the packs resistance?
Even better, why not use a charger (hyperion duo and fma 10s are two that I know of) that will tell you the batteries internal resistance, I think that would have to give you a good indication of cell quality.
edit: just notice in the pdf's above that the impedance @1khz is listed. I always thought a packs resistance would be say the average of the resistance during a discharge using V = IR. Is there some other method of testing? I also realised that those chargers measure it during charge, and say that the figure gets more accurate the longer it is charging for. any light on this?
lutach
lutach's Avatar
04.29.2008, 08:06 AM
Max Amps should get one of those CBA and run some cycles through the packs at 10C, 15C and 20C to see what they really are. I know normal guys that has a CBA and MA as big as they are should have one too. I know they won't know how to explain why they post 20C ratings on a 15C rated cell. Maybe they can just apologize and say they got money hungry. It looks too much like a "Sponge Bob Square Pants" cartoon where they Sponge Bob and Patrick were selling chocolate. They were having trouble, but they saw a advertisement for some chips and got an idea of elaborating the truth. I like the one where he says, "Chocolate will make you younger."
P.S.: I'm forced to watch it .
glassdoctor
TEAM FUSION
glassdoctor's Avatar
04.29.2008, 09:36 AM
I have done similar basic tests using a datalogger.
All you have to do is get the amps up.... to see how low the voltage drops at those points.
Keep track of the temp of the packs being tested too. Cool lipos don't perform nearly as well as a nice warm pack. My tests showed a big difference between say 60s* and 90s*
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
skellyo
skellyo's Avatar
04.29.2008, 09:42 AM
If I had the batteries and some spare time, I'm sure I could run some very accurate discharge tests on any of these batteries. One of my more recent programs here at work had 2 - 6kW programmable load boxes ( http://nhresearch.com/Products/4700-...onic-load.html ) that could be set up for a constant current load so that you could verify voltage under a specific load. It could also be programmed such that you can cycle through current spikes at various intervals. Add a data recorder to that and it would be real easy to plot the current versus voltage in a very controlled situation. I may have to look a little further into where all the equipment is now to see if it's something that would be feasible to come in and do on a weekend. Is this something you guys would be interested in seeing if I could do it?
DrKnow65
DrKnow65's Avatar
04.29.2008, 09:56 AM
Skellyo, absolutley! I'd love to see graphs of MaxAmps, Neu Energy, FlightPower, TrueRC, Zippy Lipo, and those cheapy no name ebay packs.
I think knowing the voltage drop at the rated "continuous" and "burst" amperages would be a good indicator of what works and what doesn't. How much the cells heat up at the "continuous" amp draw would also be an indicator of potential life span.
Sammus
Sammus's Avatar
04.29.2008, 09:57 AM
I'm guessing you would end up with something like the graphs of the enerland testing posted earlier. It would also be good to have them compared with similar voltage/mah A123 packs, and to have the temperature logged all the while.
johnrobholmes
johnrobholmes's Avatar
04.29.2008, 10:04 AM
Maxamps does have a CBA, Jason posted up about it a while back on RCC. Still no data from them....
I feel like getting one just to play around with. New revo, or CBA? Tough choice.
lutach
lutach's Avatar
04.29.2008, 10:09 AM
I woder why he doesn't post real graphs from using the CBA . If I had a CBA, I would be having fun with it .
04.29.2008, 10:59 AM
Hmm, I wonder why too
lutach
lutach's Avatar
04.29.2008, 11:06 AM
Hey lincpimp, look what you started my friend . You made Jason have a melt down . I now have what I need to not buy a MA pack ever again.
skellyo
skellyo's Avatar
04.29.2008, 10:29 AM
I did some looking at the CBA you guys were talking about. It looks like it would be around $1500 + shipping for everything needed to test 2S packs. That would be the CBA, 2 - 500W amplifiers and a 1000W harness kit.
johnrobholmes
04.29.2008, 10:13 AM
I don't know why. He is passing anything I say as just "hating" at this point. Jason has directly stated that good news is "truth" and bad new is "claims" in that thread.
I have a feeling I could post up 10 graphs and he would give me 10 reasons why they didn't say anything about the packs. Really disappointing to see somebody in our industry so unwilling to accept anything but what he wants to hear.
lutach
lutach's Avatar
04.29.2008, 10:28 AM
Wow. He actually said that?
kulangflow
Never Fast Enough
kulangflow's Avatar
04.29.2008, 10:43 AM
Sorry John, but it looks like Jason booted you and erased all your posts from NK because of your "hating".
I keep wanting to defend your good name there, but I don't want it to compromise my ability to get answers from them. I'm sure I would immediately be booted like you were.
lutach
lutach's Avatar
04.29.2008, 11:03 AM
That's not a good sign from MA at all. Are Austin and Jason relatives or maybe best friends, but if they are none of the above, I would seriously start restructuring the company ASAP. Get better products and qualified people to handle issues with the out most professionalism so their actions won't make the company look even worst. I bashed a little in rctech regarding the Speed Passion GT controller, but those guys handled that well. Jason has also shown us that he doesn't know how to deal with pressure at all. Good point was when lincpimp posted in the MA thread.
