09.16.2005, 05:25 PM
Okay! I just wanted to make sure. :) Would you have a turn to suggest serum. I was thinking about 10 or so.
Peace!
Country
Help support the
Rc-Monster
Buy here
09.16.2005, 05:33 PM
With a centerdiff? or what gearing ratio and what cell count?
09.16.2005, 05:38 PM
I will most likely run a tranny for now. I was thinking of a center diff. I not sure yet.Gearing is up for grabs. I figured i should be able to run a little higher gearing than with the 9xl. You have more experience than I serum. I am open to suggestions. I just want power. :D
Peace!
Country
Help support the
Rc-Monster
Buy here
09.16.2005, 05:43 PM
How many cells?
20-24?
09.16.2005, 06:03 PM
I was going to run from 16 and up. The up is un sure of yet. I was thinking that if i go with the 10 and run 16 to 20. If i change the motor around I could pack 30 or so. I may try it on more than 20 if it does good on 20. Have to figure on the kv rating and such.
Peace!
Country
Help support the
Rc-Monster
Buy here
09.16.2005, 06:26 PM
well, there is some difference between 20 and 30 cells, but in 20/24 cells the 2250/10 or 11 should do (not very much difference in KV.. with 30 cells i would also aim for about the 25-30 k rpm range. Don't boughter the low RPM, you'll get more than enough torque back for it....
09.18.2005, 08:12 AM
What do you think about a 2250 10 turn? Run anywhere from 16 to 24 cells. I think the 2250 will be good for that.
Peace!
Country
Help support the
Rc-Monster
Buy here
Brushless Heavy Weight....
09.18.2005, 09:29 AM
I think that would be perfect.....
09.18.2005, 09:49 AM
You might need to change your range of gears (pinions/spurs) but it sounds like a charming one to me.. Consider a centerdiff, it helps you find the right gearing a bit easier.
09.18.2005, 11:20 AM
Okay! I will check out a center diff. I may need it help it drive better. It drives good now any way.
Peace!
Country
Help support the
Rc-Monster
Buy here
09.18.2005, 11:33 AM
Centerdiffs are uber..
09.18.2005, 11:41 AM
You lost me serum with that one. What is uber?
Peace!
Country
Help support the
Rc-Monster
Buy here
09.18.2005, 11:52 AM
Great, fantastic, greater than great..
09.18.2005, 12:05 PM
Center diff would be awesome.. but spent too muchmoney on Tranny and CVD's... :(
09.18.2005, 12:11 PM
Come on.. That's no reason... ;)
