nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
11.15.2005, 05:15 PM
Grr, dafni isnt online!! aww wel! I gotta drill holes for e-maxx tranny holes. What size drill bitts u used? Is it normal for my 10t pinion for the gears to be barely able to touch teh spiked part fo the 70? Like the spikes on the pinion are 1/3rd the size of teh spikes on the spur... I got a really stripped 72t that works perfectly with it. Found it in a toolbox. The spikes are worn down to trapazoid shapes but it works better then my other one. Ima go to my school and my teacher will help me make them batt trays and stuff at teh metal shop. Whats the specs of ur batt tray and rollbar thing. What material did u use to cover the battery trays with? Should i buy gorrilla straps? Can they even work on ur battery tray?
~~~~~~~~RC Garage~~~~~~~~
LSP-R - Picco .26
Nitro Revo - .18tm
Dafni
Dafni's Avatar
11.15.2005, 05:26 PM
Well, here I am! :)
If you want to use 3mm screws (they fit the tranny case) then a 3mm drill bit would be perfect.
I use 3mm sheets, but 2.5mm or even 2mm should work for batt trays. As for specs, just meassure your packs, and use a bit of imagination. My first design here is not the best. I would do it different now.
I use some foam stuff with thin double-sided tape for cushioning and anti-slipage duty. Stuff feels pretty similar as the foam on the gorilla products.
As for your spur: Almost sounds as if your other spur is another pitch. If the gears wont fit into each other, then they are no match. btw, those spiky things are "teeth".
Good luck on this project.
nbcaznmaster
11.15.2005, 08:13 PM
Lol, i knew taht! just forogt to use it! what u mean? coolhnad gave me the pinione! did he RIP ME OFF!?!?!?!? so far so good, the problem is that the drive shafts are hitting the cahssis. Just barely! ima file some more off on the other side and center a lil more... Everyhting is almost ready for a 2-wd revo! lol. Where do u mount the reciver? Pics? How would u do different?
LSP-R - Picco .26
Nitro Revo - .18tm
coolhandcountry
coolhandcountry's Avatar
11.15.2005, 08:24 PM
Yes I ripped you off. I gave you a 10 tooth pinion 32 pitch with the motor. ;) Next time I buy a motor want some one to rip me off like that. :D That be okay azn dude. I won't sell you the schulze for that remark. ;)
Peace!
Country
Help support the
Rc-Monster
Buy here
nbcaznmaster
11.15.2005, 08:26 PM
lol, i was j/k! i shoulda put that in there! u never rip me off! it works with this other spur i found so i dont care!! STill a great deal!!
LSP-R - Picco .26
Nitro Revo - .18tm
nbcaznmaster
11.16.2005, 11:22 PM
how cna i make the battery tray better?
LSP-R - Picco .26
Nitro Revo - .18tm
nbcaznmaster
11.16.2005, 11:30 PM
HOw wide and long is the 9920? I wanna make that holder dafni got for his 9920. Im fabricating the parts tom at school, so i cant wait for the 9920 to come in.
LSP-R - Picco .26
Nitro Revo - .18tm
