For the "Rustler" fans, I'll be running again this weekend
I've installed the new version MIP's & will be running 4S2P 6600...everything else is much the same however I'll be advancing the timing a little to see what I can wring out of the TP cells
I will at some stage see how long the MMM will cope with 8S also. Does anyone have any opinions about how long it will last?
I've heard/read of others doing short runs on up to 10S without damage to the MMM. I also used my series plug late one night by mistake after a few repairs during a bench test without any problems...I'm always gentle on the bench for obvious reasons
Basically, I'd like to understand what the MMM is capable of running in the "real world"
Well, in the "real world" it's rated for 6s. I can't understand why you would try to run it 33% over the rated voltage. I take it you will run the same motor? Same gearing? If one of those doesn't change it's gonna be toast. If not when you accelerate, then when you brake. Sorry to sound so "glass half empty" but you're basically testing to see whether you can waste $220. $150 for the ESC and $70 for the replacement. Plus shipping.
Nobody believed I could run stock sliders to 87mph (must admit I surprised myself too), in fact most RC people are skeptical of almost everything until proven wrong. I'm not out to prove anything to anyone or to build a better box but I enjoy the odd careful experiment. If it all goes wrong, well I guess the V2 will end up in the junk box & a V3 will be ordered
No speed run but a bit of showing off pegging the throttle from a standing start with my new MIP's saw the end of my transmission gears...the MIP's stood up to the twin 8' stripes down the road
The first and obviously the last time I've done that...and I know I should know better but seeing those stripes on the road tomorrow morning will be worth it!!
