SV6000
SV6000's Avatar
12.11.2009, 04:02 AM
Here she is
CUBIC INCHES = CUBIC HORSEPOWER = CUBIC DOLLARS
SV6000
SV6000's Avatar
12.11.2009, 04:04 AM
After seeking some advice and speaking to the guys at schulze i decided a bigger speedy was the go, so i went with the future-xl-40.160WK. Here is a photo of it compared to the 24.150
SV6000
SV6000's Avatar
12.11.2009, 04:08 AM
As i said earlier i wanted a mechanical brake setup if for nothing else because it looks cool.
I ended up with 4 wheel disc brakes that function very well and have no trouble pulling the truck up. I still need to do some more testing to decide if i will keep them or not.
SV6000
SV6000's Avatar
12.11.2009, 04:12 AM
Here is how it all actuates
I still need to trim the wires and crimp the ends once the brakes are adjusted for bias. At the moment they are adjusted for full lock front and rear.
SV6000
SV6000's Avatar
12.11.2009, 04:17 AM
And to finish off here are a couple of photos of my DM 1
Mikak
AKA: MJBE
12.11.2009, 04:54 AM
Very Impressive
  Send a message via Yahoo to Mikak Send a message via MSN to Mikak
Popoxx
Sapere aude
Popoxx's Avatar
12.11.2009, 06:15 AM
Awesome work ! I love the mechanical brake setup Did you made it or bought it ?
12.11.2009, 11:19 PM
God damn that incinerator unit/esc is huge!
Looks awesome though, nice job
EDIT: wtf-mech brakes on a revo? Got any more info or a link to what you used for those?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.11.2009, 11:31 PM
Super Cool !!!!!!
Revo with Mech Brakes, TITS !
Please tell how you stripped and polished the 2200Motor ?
SV6000
SV6000's Avatar
12.12.2009, 12:11 AM
The brake kits are for a BAJA and i modified them to fit. The company that makes them is, well inXXXXtgy sorry don't know if i can say that word here.
In order to get them to fit i had special hubs made up that are 24mm hex to start with, drop down to 17mm hex for the rims and than the standard traxxas thread. I noticed how much the standard traxxas hubs wear when i first ran the truck so those hubs are an interference fit. If you didn't put the retaining pin through it would still turn and the wheels would not come off, in fact with out a hammer you wont get those hubs on or off.
I also had the cable holders made up, everything is made from 7075
Here's a link http://www.integy.com/st_prod.html?p...94&p_catid=126, you will also need a very strong servo, http://www.hitecrcd.com/servos/show?name=HS-7950TH i use one for steering as well. The cable are all shimano racing bike cables as the stock ones are very average.
SV6000
SV6000's Avatar
12.12.2009, 12:13 AM
Super Cool !!!!!!
I stripped the motor down and used oven cleaner. I was very careful and used an old toothbrush to lightly agitate. Than i put the motor back together and buffed with dremel, steel wool, billet polish and microfibre cloth.
SV6000
SV6000's Avatar
12.12.2009, 12:15 AM
Hey Neil you should check out the schulze website and see the 40.300WK. Its twice as wide and comes with its own metal heat sink case. It is one big speedy.
Nard Cox
n00b
02.14.2010, 11:35 AM
Man this ride is sick!!
Any movies of this beast ? It must haul ass!
squeeforever
squeeforever's Avatar
02.15.2010, 01:23 AM
SV, would there be any possibility of getting a set of those hubs and cable holders? I'd love a set of those on my BPP Lightning Stadium and possibly my E-Revo as well.
Edit: How much of a PITA is it to adjust the camber since the disc is blocking it? Also, how is the caliper fixed to the knuckle? Its kinda hard to tell.
SV6000
SV6000's Avatar
02.15.2010, 01:44 AM
I only had the one set of hubs made, the cable holders are off the brake kit and the caliper is fixed directly to the hub. Adjusting the camber isnt to bad but it does require taking the disc off. That means undoing the two screws that hold the brake shoes onto the caliper. So not too bad really. If it really becomes a PITA i will just drill a hole in the disc at the right spot
