thzero
11.20.2010, 12:12 PM
Yes, the Flux and XL both use 11mm cups on the diffs and on the axles.
Originally Posted by Finnster View Post
The SHD axles are larger than std dogbones on the ball end. "Normal" ends are ~8mm. Those cups on there look like the normal size bones imo.
flowrider
11.22.2010, 08:02 AM
Do anybody of you know if these Baja 5B Axles may fit?
HPI 86488
http://www.hpieurope.com/piw.php?lang=en&partNo=86488
I can't find the exact diameter anywhere, just the lenght.
LiqrSicc
LiqrSicc's Avatar
11.20.2010, 11:33 AM
I think the removable cup joints for the flux are just normal sized compared to the actual stub axles which use the 11mm cup
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
  Send a message via AIM to LiqrSicc
thzero
11.22.2010, 09:11 AM
Nope, they are too big. They are 12mm. And the cup size is 15mm.
flowrider
11.22.2010, 01:25 PM
Well, I thought so but wanted to get a verification. Anyway, I just went the ridiculous expensive "5T axles" route and ordered from here due to the MUCH cheaper shipping costs than wheelspin. At least I get a lil' piece of mind that my axles should not collapse in a cartwheel or miss-landed jump. We'll see.
LiqrSicc
LiqrSicc's Avatar
12.04.2010, 09:53 PM
Did you ever get your 5T axles? I have some spacers you might want to make the adapter fit perfectly on the axle.
BTW, I never did get a chance to show what the finished project looked like so here it is:
Went with the Silverado body which I've used on a bunch of my other MTs. Looks a little short. I might have to get a F650 later on. The 5T axles are holding up although I've barely flipped this thing over once I had the suspension tuned in.
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
flowrider
12.05.2010, 06:48 AM
Well, I just received them on Friday. These things are quite heavy which is promising in terms of stability! Now I'm waiting for the rest of my Savage to show up, especially on the Cen Diffs, the 2x CC1520 (Got a CC1717 already but could not resist the black friday sale :) ), Trenchers and my DB XL Tvps.
Yes, I know I need this spacers. Already wrote the guys at the website you posted concerning a quote for max. 10 spacers + shipping. I just don't need 25 pieces which is the smallest quantity they offer. But if you have some spacers lying around which you don't need that would be awesome & I get my PayPal ready!
btw Your truck looks fantastic, but I didn't expect anyrhing else from you!
LiqrSicc
LiqrSicc's Avatar
12.05.2010, 12:34 PM
That setup is gonna be nice! So far my BP diffs are holding up. I have the 1717 too but the 1520 works out so good I don't have the need to use the 1717. I couldnt resist the sales either!
I thought you could buy the spacers individually? Well PM me your address and I can ship you out a set since I have a bunch of extras. I figured I'd get the 25pc order in case there would be a few people who tried the 5t axles as well.
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
thzero
12.05.2010, 01:02 PM
Why'd you go with the 5T axles instead of just using the XL axles? Seems like the latter might have been a cheaper option. Then again, the XL axles a prone to break where the threads begin; was that the issue?
_dV
12.04.2010, 11:54 PM
Nice, offset looks good on it.
What were the exact dimensions of those spacers? 3/16" spacers (3.57mm) wide and 8mm inside diameter? outside diameter?
LiqrSicc
LiqrSicc's Avatar
12.05.2010, 12:26 PM
Thanks! They're 9/64" wide which comes up to about 3.56mm. 8mm inner diameter and about 12.7mm outer I think.
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
toplakd
12.05.2010, 04:40 PM
Hi.
I mean those from diff to the wheel side. Center ones are perfect fit. :)
Dejan
I removed my signature.
thzero
12.05.2010, 06:08 PM
Dejan, sorry but you are not correct. What I listed were the diff cups for the XL and Flux that connect via the SHD (11mm ball) dogones to the XL and Flux axles. The cups that connect the tranny/gearbox to the rear/front dogones are the standard 8mm cups.
Please refer to the manuals:
XL: http://www.hpiracing.com/kitinfo/104246/
Flux: http://www.hpiracing.com/kitinfo/104240/
Or the European versions, which don't differ:
XL: http://www.hpieurope.com/kit-info.ph...&partNo=104248
Flux: http://www.hpieurope.com/kit-info.ph...&partNo=104242
Like I said I have three of these guys; one XL nitro, one XL convert to 5T conversion (see my other thread), and then a Flux (or will be once I decide on the whether to run a standard TVP/axles or XL length TVP/axles).
Originally Posted by toplakd View Post
Hi.
Dejan
toplakd
12.05.2010, 06:28 PM
My bad, I checked now at my car and they are the same.
I have remembered now the driveshaft was cousing problems.
I bought flux driveshafts and guy send me driveshafts with 9mm inside hole.
Dejan
Gdot
12.07.2010, 11:33 AM
i like the chev body. it looks real nice with the black wheels too
