skellyo
skellyo's Avatar
04.27.2006, 12:49 PM
Originally Posted by furryninjas
and has anyone ever ran offset rims in rear to make it wider? would this make it handle better or just run the standard offset on front, and inset on rear to make it even?
I run the standard width FLM arms on my Pede, but upgraded the front with nitro pede spindles, carriers and flm caster blocks. I also use maximizer Stampede to Maxx wheel adapters and run RPM Stablemaxx wheels for a wider stance. This pic gives you a good idea of how wide it is with these parts (keep in mind this is the FLM Ext chassis as well):
http://onelouds10.com/flm_pede4.jpg
furryninjas
04.27.2006, 07:45 PM
anyone have problems with steering turnbuckles hitting servo or chassis braces and interferring with servo motion or arms up/dn movement? can't seem to get this figured out...... does the 645 hang down too low or something, is there a more compact servo i could use? what is my problem?
coolhandcountry
coolhandcountry's Avatar
04.25.2006, 03:44 PM
some of the guys run the stock slider on the pedes with good luck. the cvds for the stock arms won't fit the extended ones.
How am I the great one? I am just a man. Maybe a boy. :D
Peace!
Country
Help support the
Rc-Monster
Buy here
Mike.L
Mike.L's Avatar
04.25.2006, 06:13 PM
they have nice parts there. but to me i think there $expensive$ parts.
  Send a message via MSN to Mike.L
coolhandcountry
04.25.2006, 07:32 PM
What is a good shock for a ped? I have heard the traxxas big bore shocks. I could use me some for mine. What about spring rate to? I need to hurry up and finish my pede. I am tired of looking at it setting there. It needs to be dirty.
Peace!
Country
Help support the
Rc-Monster
Buy here
skellyo
skellyo's Avatar
04.27.2006, 12:45 PM
I'm happy with my Duratrax Evader PRO ST shocks. I picked them up on eBay back when I was building my FLM Pede. I do suggest jumping up to the heavier green springs for them though.
coolhandcountry
04.27.2006, 08:17 PM
Have a pic of it. the 645 should work great.
Peace!
Country
Help support the
Rc-Monster
Buy here
furryninjas
04.27.2006, 10:49 PM
ok, so i had to mount it through top of chassis instead of bottom to clear the braces, and then i had to turn it around so the wires were coming out the front instead of towards the rear........ but now it turn correctly anyways.... but now, when the shocks compress the wheels toe in real bad, is this normal???
its late so ill try to get picks tomarrow.....
oh shit, little driving in yard, no longer than 5 minutes, no jumps or anything......(stock brushed motor, low battery), the little C-clip popped off the shock shaft above piston, and its too low in shock cylinder that i can't snap it back on..... GPM shocks SUCK!!!! does seem like there's enough space between 2 C-clips for the piston to fit, i think that may be why i came off so easily.... WTF!!!!:mad:1
maybe shocks from another car will fit?
furryninjas
04.27.2006, 10:57 PM
never mind, now i gotta turn the servo around again...... "servo reversing on controller", isn't that a nifty thing, LOL..... that should fix the toe in problem too..... the turnbuckles will be straight across then instead of pointing towards rear end....
coolhandcountry
04.28.2006, 07:04 AM
You get it. For the little clip. If you take the bottom of the shock of that mounts to the truck. ( the rod end) You can pull the shaft all the way thru and get to it alot easier.
Peace!
Country
Help support the
Rc-Monster
Buy here
furryninjas
04.29.2006, 08:44 AM
couldn't get rod ends off with anything i tried...... but i did eventually get the clips on, with some fightin' and some cussin'.... now i just need a brushless set-up... and ill be all set to go bashin.
furryninjas
04.29.2006, 10:15 AM
ok, so here it is so far....... shocks fixed, servo fixed (just need a new servo saver now), i like the low CG of the rusty, but i got the pede chassis cause i THOUGHT i could flip it over and have braces on top for strength, but it didn't work out, oh well, still looks alright i think, just need the front arms still and brushless motor, other than that, she's done, got new rims and tires too just haven't glued 'em yet......
plastic steering knuckle broke already too, damn couch just jumped out of now where, LOL....
Mike.L
Mike.L's Avatar
04.29.2006, 12:28 PM
nice truck
