A123 batts
pthunell
A123 batts - 10.22.2008, 07:30 PM
Anyone know how well A123 batts fit in the battery slots? I should probably just go to the traxxas website, but I try to avoid that place.
Thanks in advance.
Pete
Sammus
Sammus's Avatar
10.22.2008, 07:54 PM
Not very well. If you do a 2x2 4s shotgun pack it will nearly fit, but will stick out by a couple mm and youll need some other way of securing them in there (battery doors won't close). Or if you get the extended wheelbase rear arms, you can fit a side by side 6s pack in there which will stick out nearly an inch. (without the long wheelbase rear arms they're too close to the rear tyre).
I can't recall exactly but I think the max battery size is LxHxW = 165mm x 30mm x 51mm
stum
10.22.2008, 07:57 PM
I know the biggest pack I could find to fit in the erevo tray was the maxamps 2s2p 8000mAH lipo (20c version). This held up fine to any/all abuse and really maxed out the space for hight and width, but there was still some length in there. I saw a few photo's and the true-rc packs and SPC 8000mAH 2s lipo's also took up the entire space and were longer to boot (also weighed more than the maxamps)
Sammus
Sammus's Avatar
10.22.2008, 08:01 PM
I've also seen 3s 5000 polyquest packs in there - I'm pretty sure all the enerland cell based packs are the same size, so the other similar brands would fit too.
pthunell
10.23.2008, 11:47 AM
Thank you all for the replies. That will help in deciding if I end up getting one of these.
Pete
hailmick
01.08.2009, 08:56 AM
does anyone know if mike will be doing pre orders or even selling the bl e revo
im gonna email him but someone may be faster for a response and to dig the thread up cant wait for this thing
