My buddy that was going to test the buggy recommend that I throw out the 2 piece upper chassis's and replace them with a single upper chassis. This is because their was way to much flex front to back and he was afraid the buggy the chassis would bend if it nose dived. So..
For the last about week or so I have slowly been making a single piece upper chassis for the buggy. Next to the main chassis this part is the largest and the most difficult to make. That's why it has taken so long. The hardest part is figuring out where the shocks need to be mounted and getting the holes aligned correctly. The process I used to make this part is I drew it out on a piece of graph paper and also drew where all the holes need to be. I then made a copy of the drawing and taped it to a piece of aluminum using packaging tape so I could see where I needed to cut. I then used a hand held jigsaw to make all the cuts. After filing and drilling the piece and re drilling holes I have finished the piece.
Now after bolting down the piece the buggy is very still and I don't even think I need to make chassis braces for it.. though I'm not positive about that yet because of how thin the main chassis is.
Mind you I still have to finish filing the edges and I also will be covering it with the same flat black vinyl that I covered the last upper chassis's with and the main chassis. In these pictures you can also see the Feigao 8xl motor with rc-monster heatsink I purchased for the buggy and my new bluebird servo.
Next I will be working on reworking the battery compartment and taping my saddle pack batteries together.
